MacBook A1181 white screen
  • inspirim
    • May 2013
    • 282
    • Italy
    this notebook when you turn the screen is all white, disconnect all peripherals same problem, this is the classic apple startup sound, tried the display on a new motherboard, the display is ok
    anyone has any news about
    thanks to all
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    Re: MacBook A1181 white screen
    is it ok with external monitor ?
    • inspirim
      • May 2013
      • 282
      • Italy
      fixed connector for video unsoldered, maybe someone forced him
      thanks to all
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • harp
        White screen repairs
        by harp
        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
        05-13-2024, 03:43 AM
      • MagJ_
        MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
        by MagJ_
        Hello Everybody,
        I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
        10-09-2024, 02:51 PM
      • sofles
        Macbook Pro 16" A2141 screen artefacts, kernel panic
        by sofles
        Hi there.
        I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
        I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
        Now situation looks like this, If...
        02-05-2025, 05:05 AM
