Hp 430 G6 EC reprogramming configuration
  • questore
    • Dec 2015
    • 563
    • csongrád
    Hi Guys,
    I have this board that is not reacting to power button and not charging the battery. Every standby rail is up and running (3.3v 5v, 1.8V), lid sw and all the rest ok but "RSMRST" is never gets high and no short on the board. I suspect the EC but I cannot get to it with my programmer.
    Can anybody take a look at my made up config:
    da0x8imb8e0 KB_pins=42 LEFT DOWN 05MM FLASH=256 JENK=17 TCK=2 TMS=20 TDI=3 TDO=14 CHIP=NPCX797HA0BX
    Maybe i have missed something.
  • fixitforfree
    Samsung TV mu6179 with Mainboard BN41-02568B wont save configuration.
    by fixitforfree
    I have two Boards BN41-02568B for a UE55MU6179 of which one does produce a good picture (Board A) but can not save its configuration (even a factory reset will not work) and one board which produces a distorted picture (Board B). Learning from here the IC1604 saves the configuration of such a TV.
    Before replacing the IC1604 from Board B to Board A - would that actually solve the problem from Board A not being able to store its configuration or could there be something else wrong with writing to the flashrom? Is it even the right chip to replace or should I look out for a different...
    07-21-2025, 09:07 AM
  • ugamazing
    Anyone know how to determine RAM/SSD configuration on dead 820-01958?
    by ugamazing
    I'm hoping to find a way to easily (and reliably) determine the RAM/SSD configuration of a dead board--in this case, an 820-01958.
    I've checked all over the board for any configuration codes to compare to the schematic BOM info pages, but no luck. Chip markings not useful; I can pull some ROM dumps if anyone know which one may include configuration info. Maybe the T2 ROM? May try to compare RAM configuration resistors as on older 00165 boards, but hoping there's an easier way before doing that.
    Curious if anyone may know this. Would be very helpful for us; thank you...
    07-27-2022, 10:54 AM
  • PeqNP
    Sapphire Radeon RX5700XT IR35217 configuration
    by PeqNP
    I have a faulty Sapphire Radeon RX5700XT with a short on the 3.3V PCIe rail. I was able to trace the short to the IR35217 which is responsible for managing VCore. The issue with these controllers is, that they need to be configured. I managed to get hold of a copy of PowIRCenter as well as a compatible USB flash device. What remains is, that I don't have the IR35217 configuration for that card. Does someone here own this card and can share this configuration? As this is a reference card design I would suspect that any other reference card would do the trick as well. The configuration...
    06-30-2022, 11:51 AM
  • questore
    la-h482p rev 1.0 not reacting to power button
    by questore
    Hi Everyone,
    I have a la-h482p rev 1.0 on my desk that is not reacting to power button.
    + Every ALW a LO are present when battery is plugged (11.7V)
    + Charger shows charging led orange when charging and white LED when done charging.
    + EC_ON also high 3.1V
    + power button has 3v and goes down to 0 when pressed.
    + BIOS does not have 3v on the 8th pin (+3V_SPI never rises only 0.07milivolt risen after battery plugged)
    + PCH hase 1.5V on one capacitor on top nothing on the others
    + nothing gets hot only SIO and 3V/5V regulators are 22 C
    04-08-2025, 02:11 AM
  • 08caine15
    X455LJ REV 2.1 Optical Drive and HDD Drive cannot detect
    by 08caine15
    Hi sirs, im having a bit of a problem it's my first time encountering this kind of issues . anyone knows how and what to check in this kind of issues, at first the bios doesn't even recognize the hdd and it automatically enter bios like 1 second but when I put the ODD it feels like it 's trying to read it but still it's still not showing in bios .
    what's odd is when I only put the HDD , in SATA configuration it shows SATA 1, SATA 2, SATA 3, SATA 4 and so on . when there's only two SATA SOCKET, then i put the ODD then it only shows SATA 1 which it says NOT CONNECTED. tried to reprogram...
    08-17-2025, 11:21 PM
