Solder won’t melt on MacBook 2021 logic board – need advice
  • defdjamel
    • Jul 2025
    • france
    I’m trying to remove a component from a 2021 MacBook logic board, but I’m having trouble.
    https://www.electronicsdatasheets.co...s/tlv70733pdqn
    I’m using hot air at 480 °C with full airflow and good flux, but the solder paste is not melting.
    I know there’s a lot of thermal dissipation from the board, and I suspect the copper planes are absorbing most of the heat.
    Do you have any tips for this kind of board? Would a preheater help?
    Thanks in advance!
    • Jul 2011
    • 6055
    You need to preheat the board around the device that you want to remove and then use the hot air gun
    If you have a toaster oven set the temperature 300*F or lower all that you are interested in is preheating the board so the heat does not escape to the rest of the board but used an infrared thermometer to measure the temperature do not go by the oven temperature settings because most of the time they are not accurate
    Now you might want to remove the compartment that might be damaged by heat first
    Or use two hot air guns one on top of the board and one on the bottom and put aluminum shielding on the components that could be damaged by heat
    • petehall347
      • Jan 2015
      • 4429
      add leaded solder if possible
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8264
        Preheater and good flux, that’s all you need.
        • reformatt
          • Feb 2020
          • 1432
          If you still have the CPU heatsink on, that will absorb most of your heat if the area you are working on is near the CPU. Another factor to consider is your nozzle size. For most rework of passives and small IC's, I use a 6mm nozzle. I use bigger for larger IC's like SMC's or RAM. Remember that your hot air is really heating up the board not the component per se. So having a larger surface area from your nozzle is the key and the distance from nozzle to board is also a factor. It comes down to the nuances of your station and practicing to see where the sweet spots are. I use 460 degrees C at 50 air flow on my Quick TR1300A with a 6mm nozzle for most MAC rework. PC boards don't have all the ground planes that the MAC's do, but I only drop the temps like 10 or 20 degrees for those.
          Also if you have a cheap air station, then you should look at using a thermocouple to measure what it's actually producing. Most stations have a means of calibrating the display temperate vs what is actually coming out.
          • korben_dallas
            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
            by korben_dallas
            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
            MY QUESTION:
            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
            02-14-2024, 12:23 AM
          • tony359
            2007 Macbook logic board fault
            by tony359
            Good day all,
            I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
            Once the fan was swapped, I installed an OS and it worked fine.
            The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
            Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
            If I see that right, I have missed VCORE on L7100 (page 59)....
            01-23-2025, 06:59 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • ledbylight
            M1 A2337 Macbook - No Display, likely due to logic board
            by ledbylight
            Hi all!
            This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
            I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
            11-04-2024, 06:36 PM
