820-02020 a2338 motherboard has a ppbus short to ground
  • kjchatman
    • Dec 2012
    • 209
    • united states
    this machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
  • mon2
    • Dec 2019
    • 14355
    Flux and remove fuse @ F5200. Then power up again and measure the voltage to ground on pcb pad # 1 on the removed fuse @ F5200. Is the voltage present and stable? What is the voltage?
    Then remove all power. Meter in resistance mode. Measure the resistance to ground on pcb pad # 2 on the removed fuse @ F5200.
    • kjchatman
      • Dec 2012
      • 209
      • united states
      12.38v is stable on #1. direct short to ground on #2. 0.3 ohms
      • mon2
        • Dec 2019
        • 14355
        Inject 1 volt (not higher) onto the pin #2 side and test who heats up. If it is a capacitor, it will crumble / crack under the pressure. The fault may be the CPU but TBD.
        • kjchatman
          • Dec 2012
          • 209
          • united states
          was a bad cap
          • mon2
            • Dec 2019
            • 14355
            Board booting ?
            • kjchatman
              • Dec 2012
              • 209
              • united states
              it boots
              • playit
                450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                by playit
                hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                09-02-2023, 02:43 AM
              • MisterAIL
                820-00840 / No boot / PP3V3_G3H Short to ground
                by MisterAIL
                Firstly sorry for my english, french guy inside.
                I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
                History is a day, nothing happened when opening the laptop.
                Nothing special inside, no corrosion, no liquid damage, never opened.
                First, with the logicboard alone on the desk, mesures are :
                5v017 and 0.000 amp. nothing else.
                Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
                10-13-2021, 11:42 AM
              • sdogs
                macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                by sdogs
                Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                06-27-2025, 01:58 PM
              • sdogs
                by sdogs
                06-27-2025, 11:26 AM
              • triplefour
                Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                by triplefour
                Samsung UN55ES7003
                made house call.
                red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                psu has self test feature.
                disconnected from mainboard.
                determined PSU ok BL ok.
                suspect mainboard.
                disconnecting tcon has no change on operation.
                markings on mainboard:
                BN97-06531P 0151
                BN94-06123R
                found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                for 54$
                second house call:
                with replacement mainboard, tv turns on, has sound,...
                07-13-2022, 03:53 PM
