HP Pavilion DV5-1210EQ Power off after 1 second
  • kalin89
    Wisdom seeker
    • Aug 2014
    • 8
    • Bulgaria
    Hello to my favorite electronics forum. You guys helped me many times just by reading through the posts here. Thank you.
    Now to the point.
    My situation is this :
    I have a HP Pavilion DV5 with no signal, fans spin up and capslock blinks with error code "General system board failure". These boards are notorious for their graphical chip going bad. So i did the usual re soldering and heating the vga chip (ATI) and the chipset also.
    But now, when i power it up it , the lights come on and after 1 second they go off. During that time the mosfet in the picture below heats up tremendously. Tested it with a Dmultimeter between pins 2/3 and 6/7 and the reading is 66.7 Ohms. THe mosfet is this.
    Also found out that the capacitor (also in the picture below ) reads a "Short" when testing with diode (acoustic) test. Is the capacitor causing the heating of the mosfet and my whole problem?
    Also how can i recognize what type of capacitor it is ? (How many Farads, voltage? Are these 390 2.5v the values of it? or is it something else?)
    Any help of any kind will be greatly appreciated. Thank you.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    Re: HP Pavilion DV5-1210EQ Power off after 1 second
    390uF 2.5V
    • kalin89
      Wisdom seeker
      • Aug 2014
      • 8
      • Bulgaria
      Hello again. I have replaced the capacitor and the mosfet displayed on the picture attached above, the problem persists.
      I've found out something new though : On the attachment below, the highlighted mosfet is shorted with mass ( PCB Ground ). Is this normal or this presents a further investigation and or replacing of the highlighted mosfet?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3590
        • slovakia
        dont replace mosfets until u know where is that short. remove coils or jumpers to locate the short
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          well my friend , if you don't have a good ESR meter i advise you to locate in which line is located the mosfet were its shunted to ground , and see which voltage line it it . if you don't have a good ESR meter , remove cpu and ram , and imagine for EX it was the 1.8 volts line for ex .. lift one leg of the coil in that circuit part and with black probe of multimeter on the GND and with the RED probe touch in contact were the coil stand (use OHM scale start with 2k and see which values you got on both sides of the coil (with coil lifted) and you should have a higher value in ohm ... if you have for ex 2 or 3 ohm , there is a short and were you notice a very low ohm value solder a wire to that pin(were the coil stand) and start applying a minimal voltage FOR EX (if its 1.8volts line) start applying 1V and give a good bit of current(you must use a good power source (lab source) and start to chek were you found a spot were you will notice some more heat , usually it will take you to the bloody component (attention) this is not the best method but if you don't have a good EST meter to follow the circuit , its the best chance you got to found out were the culprit is .. and in major cases if you reflowed the chipset , you might ended up merging some balls under the bag's making it to give you false encounters with components. it requires time keep us posted of the thing you will found out
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            well checking also now the image you showed us there is no problem with that power mosfet , if computer turn on and off , you still have 19volts power line working , and this powermosfet is on the really beginning on the main 19 volts DC in . focus on the first picture , i really don't have schematics at home , all is at lab to help you out better with this , but if this started to happen after reflowing chipsets , its most probable you damaged on of the chipset , now only checking with schematics i can tell you what have you damaged. so don't carry out more test , until we give you correct answers. i hope it help you out
            • sopik78
              • Nov 2013
              • 517
              • Czech Republic
              That problem might be on 1.1 and 1.2V power rail, try PQ41 or PQ42, common problem on these laptops.
              • kalin89
                Wisdom seeker
                • Aug 2014
                • 8
                • Bulgaria
                I have found a couple of schematics, but I'm not sure which one is it for my PCB
                Here they are :
                This one
                And this one
                • lefos
                  • Nov 2013
                  • 321
                  • Greece
                  First I will try to remove the northchip (the small ati one). It might have got shorted when you did the reflow.
                  • kalin89
                    Wisdom seeker
                    • Aug 2014
                    • 8
                    • Bulgaria
                    Yes indeed the problem started after the reflow of the ATI GRAPHICS chip and the AMD chipset right next to it. I think i will try what lefos said, pull out the AMD chipset next to the graphics chip and test again for shorted components etc. But what is the best way to do that and the safest way to place it back in afterwards ? Never done that before.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Measure on the tiny capacitors on top of both BGA chips. If on any of them you get short (under 1 ohm) the chip is dead and needs to be replaced.
                      You will need to buy or build a BGA reworking station to replace these chipsets. It takes a lot of practice to learn how to do it.
                      A working TV? How boring!
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3590
                        • slovakia
                        just check resistance to ground on power rails for ATI IGP. i bet it is shorted
                        • kalin89
                          Wisdom seeker
                          • Aug 2014
                          • 8
                          • Bulgaria
                          I tested as Th3_uN1Qu3 said. The tiny capacitors on top of both BGA Chips report a short. They are also shorted with ground ( as seen in picture below). Just for reference i've tested the distant AMD south bridge who wasn't touched at all or heated up. All of his tiny capacitors report 30+ ohms.
                          • Ramee
                            • Jul 2014
                            • 218
                            • Israel
                            Change the shorted cap with a good one, see if you get the same reading.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              If all caps read short, then one or both of the BGAs are dead. They share the same power supply so if one is dead then the other will measure that way too.
                              If you don't have reballing tools i would write this one off as beyond repair.
                              • kalin89
                                Wisdom seeker
                                • Aug 2014
                                • 8
                                • Bulgaria
                                Indeed. I wrote this one off. Wasted too much of my time on that already when i have more important projects ahead Thank you everyone for the support on this one. Helped me alot .
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  attention that what you showed us in the picture dont tell that cap is in short , some of the capacitors have one of the sides turned to the GND so its normal that there is continuity , alltough if both sides are making continuity than its not good .
                                  bether to test between each sides on scale of 200ohm , it you have less than 1.1 ohm , then very possible there is a problem with the capacitors or the powerrail that feed that line.
                                  very common on DV5 series , i have now one in the bench with similar problem . cheking very carefuly the 1.2v line
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1488
                                    • portugal
                                    alltough mine i found PD1 burned
                                    replaced it and turn the dc in again and noticed the PD1 to get a bit hot , but having the +5vpcu on one side . made a replacement to PU1 sice the capacitor and resistor was ok . then noticed dc led flashing .... cheked that pq41 was not passin the 19 volts , also no 28 v gate on the pin of pq45 , lifted the drain leg of pq45 and instantly dc led light up ,and there is 28 volts on gate so , 19 volts is in short , grabed the power lab source , and found pq42 getting hot . removed the pq42 , and sodlered again the drain of pq45 and board now turn on , and make the one flash caps lock .
                                    ok replaced the mosfet that was burned ,. but once again dc led flash again damaged mosfet . removet mosfet all good again . so cheked resistante to ground no the source of pq42 and i got around 6 ohm ... not enough for short but for sure very low resistance. cheked pq56 and its ok , also cheked pq 41 ok as well , if i chek on continuity it tells me , that PC150 makes continuity t GND as also the coil and the pq41 .. pff getting tired .. so start injecting 1.2 volts , nothin get hot .. cheked with multimeter lab source is gving 1.2 but im readong 0.5 volts , so strt increasing until i have 0,78 volts on board and lab source is at 2.5 volts allreadt and almost one AMP consume .. nothing is hot ... its not possible , its more than 5 w so it would be something getting hot .
                                    any taughts mates ?
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      well guess tomorow will spend more some hours around it
                                      • nkgm
                                        • Feb 2015
                                        A bit late to the party but facing the same problem. Some of the caps on the GPU and NB appear shorted. I trust your appraisal it's the BGA's, but could it not be that the short is happening elsewhere?
                                          HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
