Lenovo Legion 15ach6h ic chip fried
  • Lenovochris
    • Aug 2024
    • 59
    • United Kingdom
    Can anyone help with id for it please
    Pu6601 location on board
  • mon2
    • Dec 2019
    • 14321
    Silergy SY8288RAC AWSxyz IC
    https://www.aliexpress.com/w/wholesa...tesla.search.0
    • Lenovochris
      • Aug 2024
      • 59
      • United Kingdom
      Originally posted by mon2
      Thanks for that, It's just a case of soldering on yes?
      • mon2
        • Dec 2019
        • 14321
        Correct. Flux and remove first. Clean the pads - be patient and watch lots of YT videos. Not wanting to burn the board nor remove the small PCB pads that keep this QFN package onboard. Practice on donor boards to get a feel. You will need hot air tools for sure or work with a good local cell phone tech.
        Once the regulator is removed, test the resistance to ground on the output pins to confirm there is no shorted part onboard. That is, this part did burn out for a reason and it may be due to an excessive load.
        • Lenovochris
          • Aug 2024
          • 59
          • United Kingdom
          Thank you for that, i have a hot work gun and flux and have done bios chips etc and caps before, but really appreciate the advice. As we are all here to learn. I'll be on contact again when I have removed the old one , Hopefully will go smoothly, 400 degrees c for removal or less, thanks
          • mon2
            • Dec 2019
            • 14321
            Measure the resistance to ground of PL6601 (without power to the board). Is it with a very low resistance? Trying to understand why this regulator fried.
            • Lenovochris
              • Aug 2024
              • 59
              • United Kingdom
              Thanks for your help. Unfortunately upon chip removal there is evidence the chip exploding has caused irreparable damage to the board surface.
              So I have ordered a second hand board with. Same part number etc,
              This has a fault of its own but I don't want to but new just yet,
              It goes no display but displayed on hdmi previously apparently if swap my old bios chips from old board to new, will this retain the s/n etc from the original laptop.
              • m1ch43lzm
                • Mar 2019
                • 480
                • Peru
                If you're getting picture via HDMI, the issue is most likely not the BIOS
                For the S/N, etc, on AMD laptops you can swap the main BIOS with no issue, on Intel you have to clean ME region, or edit the BIOS from the working board with the S/N from the dead board
                No need to swap anything which "looks like a BIOS", only swap UB3 (or UB2), W74M12JWSSIQ or W74M25JWZEIQ whichever is present
                Some boards use a MUX for switching the display between the iGPU and dGPU, others connect the LCD to iGPU, and wire the HDMI port to the discrete GPU, check the schematics
                If your board is NM-D562 the schematics are here https://www.badcaps.net/forum/troubl...-and-boardview
                it has a MUX, UV12 PS8461E, replace it with the one from the dead board, then check if you have picture on the Internal LCD
                • Lenovochris
                  • Aug 2024
                  • 59
                  • United Kingdom
                  IHi
                  Thanks for the response,
                  I've attached the description of the boards faults from the previous no owner.
                  It is indeed an Nm-d562 rev 3.0 Both are Ryzen 7 5800h motherboard with 3070s
                  • m1ch43lzm
                    • Mar 2019
                    • 480
                    • Peru
                    The power off issue after X seconds may be a similar issue as this one
                    https://www.badcaps.net/forum/troubl...ter-34-seconds
                    Also check if it responds to pressing Caps Lock on the keyboard while it's on (caps lock LED should toggle), if it does then the no display issue could be a faulty mux
                    • Lenovochris
                      • Aug 2024
                      • 59
                      • United Kingdom
                      Ok thanks, when I get home tonight I will check and update, sorry for.my ignorance what is an mux.
                      • m1ch43lzm
                        • Mar 2019
                        • 480
                        • Peru
                        Mux is abbreviation of multiplexer
                        https://en.m.wikipedia.org/wiki/Multiplexer
                        Think of it as a controlled switch, you have the display outputs from the AMD graphics built in the CPU, and the NVIDIA GPU, it's used to switch between those to the internal LCD
                        When the BIOS is set to "Integrated" it tells the mux to route the display output from the AMD iGPU to the LCD, and when running a game it will switch the LCD to the NVIDIA GPU
                        When it was set to "discrete", it's set to route the display output from the NVIDIA GPU to the LCD (the AMD iGPU is disabled), that's why the seller claims it showed display from HDMI only, as the HDMI port is wired directly to the NVIDIA GPU
                        That's why I suspect a faulty mux, check page 45 of the schematics
                        • Lenovochris
                          • Aug 2024
                          • 59
                          • United Kingdom
                          Ah ok
                          Thank you.for that I will look through and see if I can understand it thank you..
                          • Lenovochris
                            • Aug 2024
                            • 59
                            • United Kingdom
                            Ok
                            So I installed the used motherboard to test.
                            Fans come on on start up like normal and go off
                            Keyboard lights on, caps lock doesn't toggle light on
                            Fans kick in for a period of time then the whole machine shuts down,
                            I don't have a great understanding of schematics, I did have look and all it did was confuse me.
                            I can't seem to find uv12 on the board or the temp ic chip for the apparent shut down issue
                            Am I looking in the wrong place,
                            I've attached pictures of the old board could you circle the area I should be looking in. Sorry to be a pain.
                            Thanks for all your help.
                            • m1ch43lzm
                              • Mar 2019
                              • 480
                              • Peru
                              The boardview should help https://www.badcaps.net/forum/troubl...10#post3178010
                              Open with FlexBV Free https://pldaniels.com/flexbv5/
                              UV12
                              • Lenovochris
                                • Aug 2024
                                • 59
                                • United Kingdom
                                Ah perfect thank you,
                                This will be my first job tonight then I will let you know how I've got on, thank you so much
                                • Lenovochris
                                  • Aug 2024
                                  • 59
                                  • United Kingdom
                                  I think this is the one, any advice on lining up when resoldering to make sure all pins line up?
                                  • m1ch43lzm
                                    • Mar 2019
                                    • 480
                                    • Peru
                                    Here's some videos how to solder QFN, you need a microscope to inspect the pins for shorts
                                    https://www.youtube.com/watch?v=ozD5NELBpP0
                                    https://www.youtube.com/watch?v=kmX_oLPy08o
                                    www.youtube.com/watch?v=uLEyxEF6_MU
                                    https://www.youtube.com/shorts/9vicndfU5sA
                                    Practice on dead boards first
                                    • Lenovochris
                                      • Aug 2024
                                      • 59
                                      • United Kingdom
                                      Thanks for the links very helpful, will give it a go tonight and see how I get on, will let you.lnow the results.
                                        LENOVO Legion Y720 Legion 1800x Specification for Upgrade or Repair
                                        This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                        09-12-2024, 02:30 PM
                                        LENOVO Legion T530 Legion i5-8400 Specification for Upgrade or Repair
                                        This specification for the LENOVO Legion T530 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion T530 boardview and Legion T530 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                        LENOVO Legion Y720 Legion 1400 Specification for Upgrade or Repair
