Dell Vostro 15 3568 15341-1 91N85 - Won't recognize battery and charger
  • Iherduleikgemz
    • Jan 2020
    • 22
    • Poland
    Hello everyone
    I have been working on this laptop mentioned in the title, it initially had a blown PQ4410 mosfet. After I replaced it and repaired the damaged PCB the thing started working again, but there is still another problem. The laptop won't recognize genuine battery and charger. I have 3.3v KBC PIN36 PS_ID and this is pretty much where my knowledge ends.
    Where should I go next? Replace the KBC or measure something else?
  • mon2
    • Dec 2019
    • 14723
    What is the voltage to ground of PS_ID_R2? This is the leg of the wiring that mates with the center pin on the actual DCin power connector.
    Be sure the center needle pin of your adapter is not broken / bent to one side. Be sure your DCin connector is actually mating with the same pin.
    • Iherduleikgemz
      • Jan 2020
      • 22
      • Poland
      Genuine 45w charger shows 3.3V
      Aftermarket 65w charger shows 2.3V
      • mon2
        • Dec 2019
        • 14723
        Remove all power. Measure the resistance across PR4305. It should be ~33R ohms. The mosfet in series and this series resistor are a common point of failure.
        Can you confirm the needle pin inside the original power adapter is present and straight?
        • Iherduleikgemz
          • Jan 2020
          • 22
          • Poland
          The value of PR4305 is 33R ohms. Neddle is present and straight. Also i've unplugged the charger connector and the voltage to ground on PIN 4 (white wire) is 0V on aftermarket 65w charger and 0.07V on original 45w charger
          • Iherduleikgemz
            • Jan 2020
            • 22
            • Poland
            Im gonna borrow another charger just to be sure.
            • mon2
              • Dec 2019
              • 14723
              The PS_ID is a parasitic 1-wire ID device by former Dallas Semiconductor / Maxim Semiconductor (now Analog devices). This 1-wire device resides inside the power adapter and is powered by the pull-up voltage on the motherboard. Using this as the power source, the ID chip should communicate with the EC to share the properties of the power adapter. You can google for more details on how this works but the center pin must mate with the DCin connector for all of this to work. The EC is the 1-wire bus master.
              • Iherduleikgemz
                • Jan 2020
                • 22
                • Poland
                I've tried another genuine 65W dell charger and guess what... it's working and the battery is charging. Well again thanks for the help and kinda sorry for wasting your time with my rookie mistake.
                • PowerAmpFreak
                  Dell Latitude 7280 does not recognize charger
                  by PowerAmpFreak
                  I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                  Any common faults that could be fixed?
                  I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                  How does the communication between the charger and the PC work?...
                  07-28-2025, 07:18 AM
                • motormayhem
                  Lenovo T460 Only Charges on One Charger
                  by motormayhem
                  Laptop Question
                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                  05-12-2023, 01:46 PM
                  DELL Vostro 3568 Notebook 3000 Specification for Upgrade or Repair
                  This specification for the DELL Vostro 3568 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3568 boardview and 3568 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3568 Notebook...
                  09-06-2024, 12:36 PM
                  09-06-2024, 07:25 AM
