Infinix Inbook Y2 Plus no Charge
  • Dises
    • Jul 2017
    • 8
    • Russia
    Hello
    Notebook Infinix Inbook Y2 Plus, MB EM_TG325_200B_V1.0. Power on but no charge.
    The laptop starts and runs. When connect AC, it shows that it is charging, but the consumption is 0W.
    Charger BQ24715:
    no Batt / plug AC with Batt / no AC with Batt / plug AC
    ACN 22.7 ACN 14.2 ACN 22.8
    ACP 22.7 ACP 14.2 ACP 22.8
    CMSRC 21.2 CMSRC 0 CMSRC 21.4
    ACDRV 23.7 ACDRV 0 ACDRV 23.8
    ACOK 2.5 ACOK 0 ACOK 3.7
    ACDET 5.8 ACDET 0 ACDET 5.8
    IOUT 0 IOUT 0 IOUT 0
    SDA 3.5 SDA 0 SDA 3.8
    SCL 3.5 SCL 0 SCL 3.8
    CELL 3.3 CELL 0 CELL 3.6
    BATDRV 1.5 BATDRV 6.1 BATDRV 6.3
    SRN 1.5 SRN 14.6 SRN 14.5
    SRP 1.5 SRP 14.6 SRP 14.5
    GND 0 GND 0 GND 0
    LODRV 0 LODRV 0 LODRV 0
    REGEN 7.0 REGEN 0.1 REGEN 7.1
    BTST 6.8 BTST 14.3 BTST 14.3
    HIDRV 1.5 HIDRV 14.6 HIDRV 14.5
    PHASE 1.5 PHASE 14.6 PHASE 14.5
    VCC 23.5 VCC 0 VCC 23.5
    Please, help, what need it take for the battery to start charging?
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Acdrive is too low and acn is too high.acdrive should be ,+-5v more then vcc
    • mon2
      • Dec 2019
      • 14659
      Confirm your meter battery is ok. Most of these measurements are too high. The power adapter should be ~19v.
      The dual diode on the vcc pin of the charger IC appears to be defective. On battery only, vcc pin is at 0v.
      • Dises
        • Jul 2017
        • 8
        • Russia
        I'm sorry for my English, I'm writing through a translator. The laptop is charged via TYPE-C, there is no native adapter. I'm checking with a 65W adapter from Huawei. Now I'm going to try changing the battery on the tester and measure the voltage again.
        • Dises
          • Jul 2017
          • 8
          • Russia
          Thanks, really, the battery on the tester is dead. Here are the correct readings.
          ACN 19.5 ACN 11.8 ACN 19.5
          ACP 19.5 ACP 11.8 ACP 19.5
          CMSRC 18.1 CMSRC 0.0 CMSRC 18.1
          ACDRV 20.3 ACDRV 0,0 ACDRV 20.3
          ACOK 2.1 ACOK 0,0 ACOK 3.1
          ACDET 4.9 ACDET 0,0 ACDET 4.9
          IOUT 0,0 IOUT 0,0 IOUT 0,0
          SDA 3,0 SDA 0,0 SDA 3.2
          SCL 3,0 SCL 0,0 SCL 3.2
          CELL 2.8 CELL 0,0 CELL 3.1
          BATDRV 1.2 BATDRV 5,0 BATDRV 5.2
          SRN 1.3 SRN 12.2 SRN 12.1
          SRP 1.3 SRP 12.2 SRP 12.1
          GND 0,0 GND 0,0 GND 0,0
          LODRV 0,0 LODRV 0,0 LODRV 0,0
          REGEN 6,0 REGEN 0,0 REGEN 6,0
          BTST 5.8 BTST 11.9 BTST 11.9
          HIDRV 1.3 HIDRV 12.2 HIDRV 12.1
          PHASE 1.3 PHASE 12.2 PHASE 12.1
          VCC 19.9 VCC 0,0 VCC 19.9
          • mon2
            • Dec 2019
            • 14659
            Can you link a schematic (if available)?
            The measurements are better but there are still some issues.
            Review the VCC pin on the charger IC. There should be a SOT-23 packaged (3 pins) dual diode (common cathode). When you apply only the adapter, VCC is powered OK.
            When you apply only the charged battery, VCC = 0 volts. There is something wrong here. Most likely the dual diode is defective and needs to be replaced.
            Remove all power. Meter in resistance mode.
            Locate the 2 x DCin mosfets that mate with the charger IC and will be before the ACP / ACN pins.
            Measure their resistance as follows:
            source (1-2-3) & drain (5-6-7-8)
            source (1-2-3) & gate (4)
            gate (4) & drain (5-6-7-8)
            Post each measurement. Each measurement must be hundreds of k ohms or higher else could be a defective mosfet.
            Concerned about the ACDRV voltage which is about the same as the power adapter voltage. Often this means the DCin mosfets are defective. Most likely it will be the first mosfet but do measure the resistance of both mosfets. If the mosfets are NOT defective then ACDRV voltage = adapter voltage + REGN voltage = 20v + 5v = ~25 volts on the gate pin of the DCin mosfets.
            • Dises
              • Jul 2017
              • 8
              • Russia
              You're right, the first mosfet was breached. I replaced the mosfet, everything worked! Thank you very much!!!
              • mon2
                • Dec 2019
                • 14659
                Well done!!
                • PURNAMA
                  Bios infinix inbook x1
                  by PURNAMA
                  hi all, any one have bios
                  Laptop turn on but no display
                  board code
                  EM_IC819_200B_V2.0...
                  11-17-2023, 01:54 AM
                • aquif
                  infinix xl422 bios
                  by aquif
                  infinix xl422
                  sn-XLCX422H3780038
                  this is not the original bios backup, someone tempered the bios already and on that bios laptop not turning on but on this bios laptop getting on but partially on so
                  please build this bios , no display problem...
                  07-27-2025, 12:56 AM
                • Iamjeeepoy
                  em_ic819_200b_v2.0 Boardview
                  by Iamjeeepoy
                  Hi Masters! can i request for schematic and boardview of infinix INBook X1
                  Mobo: em_ic819_200b_v2.0
                  Model: XL11
                  SN: XLCEMPHB1B01798
                  08-28-2025, 09:08 PM
                • DACENGINEER
                  Infinix X601 schematics
                  by DACENGINEER
                  Does anybody have schematics and boardview for Infinix X601 (Note 3 Pro)?
                  07-03-2020, 02:45 AM
                • reformatt
                  Asus G513 dead
                  by reformatt
                  Just need a sanity check on this one. I have an Asus G513 ROG lappie here dead as a door knocker. No volts getting past the first FET. Has a BQ24780S charger IC at least, but no schematics or board view.
                  So ACDET is low at 1.7V, REGEN is also low at 5.4V. On the ACDET pin, there's a few resistors etc and also a SOT323 package marked A7t. Now in my searches this is a BAV99W dual diode. But the datasheet doesn't actually confirm this marking either. I haven't found this diode on any other board either just to compare to. It definitely doesn't meter right, I drew this out, and it seems...
                  01-19-2023, 10:03 PM
