How can I find this chip equivalent?
  • adigrf
    • Jun 2025
    • 5
    • romania
    Hello! I saw on my motherboard DAG77MB18C0 rec C that I have a burn chip and I also found a similar one in good shape but I am having troubles recognizing and finding it online in order to replace it.
    What I can read is: DN46AP 22cf 1000 and Gemini is telling me it is a MOSFET by On Semiconductor model NVMFD5c466n
    Do you think this is real ?
    The laptop is still starting but I dont want to use it until I replace that. Based on the images, do you think I will succed with a profesional electronic technician?
  • Sephir0th
    • Oct 2020
    • 1283
    It is FDMS3664S
    FairRepair on YouTube
    • Sephir0th
      • Oct 2020
      • 1283
      Picture upload is very buggy right now. Tried again...
      • adigrf
        • Jun 2025
        • 5
        • romania
        Thank you, sir! Based on your experience, do you think I will be able to fix it? I can say that a 20years old electronics technician will help me to replace it.
        • Sephir0th
          • Oct 2020
          • 1283
          It's a question of skill. I can't tell at what skill level you coukd work. And Nobody cann tell how it looks underneath before you have actually removed the burned Mosfet. In worst case it needs serious and complicated approaches, like drilling to remove shorts and rebuild of the tracks. And even then it is still possible that the GPU is already fried, since you are working on the GPU Core supply here.
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • danielgerman681
            ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
            by danielgerman681
            Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
            Today, 01:17 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
          • rumpumpel1
            How do I find a defective RAM chip
            by rumpumpel1
            I have a ThinkPad T14 which always finds an error at a very specific address during a RAM test. I therefore believe that exactly one of the RAM chips on the mainboard is defective. How do I find this defective RAM chip?
            07-29-2025, 11:55 AM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
