dell 5391 wasp13 18769-1 n94g2
  • dangminhthuongld
    • Jul 2023
    • 21
    • Việt Nam
    my dell 5391 has an error that can't use the touchpad, I've loaded another bios but now my computer doesn't boot, it eats line 0.44 and then shuts down, won't boot anymore
    can anyone help me with this case? I loaded the old bios but it still doesn't boot
    INFO
    WASP13-MB
    18769-1
    N94G2$LA
    SVT: DT09003
    CPU I5 GEN 10​
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Which programmer you used? If old bios was working and backed up properly,then i dont see any reason for it not to boot with same bios flashed again.
    may be some resistor around bios chip misplaced?
    A pic of the bios area will perhaps help.
    In the meantime,post a request in "Bios Section" for new cleaan me bios while posting your original bios backup.
    • dangminhthuongld
      • Jul 2023
      • 21
      • Việt Nam
      so tired, still have all the power, cpu still hot, up to 0.44 then back to 0.1 and not up again
      I sent a picture of the area near the bios, hope everyone can help​
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You mean it goes upto 0.44A and then drops to 0.1A or 0.01A?(0.1A-100mA and 0.01A-10mA) Please clarify.
        Measure voltage on all coils for the brief time it turns on. may take multiple attempt to measure all coils.
        Measure Resistance to GND on all coils without any power source attached.
        PS:The bios are seems perfect without any damage.
        • dangminhthuongld
          • Jul 2023
          • 21
          • Việt Nam
          I have solved the power problem, the computer is on but does not recognize the touchpad, is it possible that the bios is faulty?
          Can you help me clear the bios?
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
          • Sathsul
            Dell Latitude 5431 issues with dumping bios
            by Sathsul
            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
            Today, 07:49 AM
          • kenkaniff
            HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
            by kenkaniff
            Product Name: HP Pro x360 Fortis 11-inch G9
            System BIOS: U94 Ver.01.08.00 10/06/2023
            Serial Number: 5CG31946F5
            SKU Number: 85W05EC#AK8
            Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
            This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
            I needed to remove bios password...
            10-01-2025, 04:32 AM
          • gizaha
            by gizaha
            02-13-2024, 07:18 AM
          • mrrubik
            Dell Optiplex 7010 micro bad BIOS flash?
            by mrrubik
            Hi folks,
            I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
            After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
            Steps I took:
            1. Read BIOS with CH341a, verified hash twice
            2. Patched
            12-23-2024, 04:11 PM
