NM-B471 Lenovo T480s don´t charging
  • master3112
    • Mar 2024
    • 87
    • Slovakia
    Hi guys
    I need help with a Lenovo T480s NM-B471.
    The device works via power supply and also via battery. However, the battery is not charging. If I start the device via battery, the power supply is deactivated and the battery is empty at some point.
    I have measured and found the following. When the mains adapter is connected, is VSYS= 20V, but this should be 15V. At the PQ102, which is responsible for this, I have 20V at the gate (pin 1). However, 15V should be there. Because the voltage is too high, PQ103, which should charge the battery, remains closed. I have already replaced the PowerController (PU101), same behavior. When the device is running on battery power, VSYS= 11.8V, i.e. the battery voltage. Does anyone have any ideas? THX Click image for larger version  Name:	NM-B471.png Views:	0 Size:	232.1 KB ID:	3653167
  • mon2
    • 14662
    Both PQ101 and PQ102 are suspects. Remove all power. Meter in resistance mode.
    Measure resistance of:
    source & drain
    source & gate
    gate & drain
    of each dual mosfet. Post each measurement. Each must be hundreds of k ohms or more if ok.
    • Sephir0th
      • Oct 2020
      • 1289
      Note that these are Dual-Mosfets. But it indeed strongly sounds like PQ101 being internal shorted when getting 20V at VSYS
      FairRepair on YouTube
      • master3112
        • Mar 2024
        • 87
        • Slovakia
        Thank you friends. I measured the PQ101 and PQ102 at first. However, they were not shorted. When switched off, the PQ101 had normal resistance from pin2 to pin7, which seemed to be ok to me. Unfortunately I didn't have the MOSFET to test it. But as Sephir0th​ writes, it is a dual mosfet. I looked at the technical data and had an AONY36352 with the same parameters. It worked. So the PQ101 was actually defective. I had never had anything like this before.
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • Nikolai Danylchyk
          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
          by Nikolai Danylchyk
          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
          Thanks in advance!...
          05-08-2025, 06:18 AM
          Lenovo ThinkPad T480s Notebook T Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad T480s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480s boardview and T480s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
          09-06-2024, 02:34 PM
          09-06-2024, 02:30 PM
          09-06-2024, 12:00 PM
