Swapped CPU from Fujitsu to Dell - boot guard?
  • estabilito
    • Aug 2020
    • 59
    • poland
    Hello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Still not aware of any trick to bypass bootguard. Btw, Was the source and target SOC same SKU?
      • 22264
      If the e548 has no boot guard you can mod the E7490 bios ME firmware. Change boot guard to 0 and fill the OEM key with 00`s of the same length as the dell OEM key. It should be ok then, but you will have to make sure the bios doesn`t get updated. If you did it the other way around and put the dell CPU onto the e548 it wouldn`t work as boot guard is burned into the chip.
      • estabilito
        • Aug 2020
        • 59
        • poland
        Can you help me with bios? honestly i don't know how to do it I attached bios from dell and fujitsu.
          • 22264
          Sadly the fujitsu has Boot guard 5 .
          • estabilito
            • Aug 2020
            • 59
            • poland
            Goddamit, as i thought - anyways, thank you so much for reply
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              All the manufacturer's are trying every trick up their sleeves to disable repairs. Simple Use and throw.
              • estabilito
                Fujitsu board with 11gen cpu boot guard status
                by estabilito
                Hi, can anyone check for me bootguard status on cpu from this board.
                Attaching bios....
                10-27-2025, 10:10 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • mpower1226
                Dell optiplex 7090 boot problem
                by mpower1226
                Hi masters, need your help in solving this mystery.
                i have a dell optiplex 7090 micro that i bought from local kijiji.
                when i turn it on, error comes out saying no hard disk.
                i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
                i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
                it seems as if the computer doesnt recognize the ssd...
                01-22-2024, 10:37 PM
              • mamado mosa
                Slow boot dell latitude 5410 laptop issues
                by mamado mosa
                So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
                The problem is it takes more than a minute to boot ..
                The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
                Can someone suggest something to fix
                06-19-2025, 06:55 AM
              • Raven7032
                Dell G15 Ryzen Edition (LA-K454P) – No SPI Activity, No Boot, No startup
                by Raven7032
                Hello everyone!
                Stucked with this problem.
                Model: Dell G15 Ryzen Edition
                Board: GDL LA-K454P
                Symptoms:
                • Board powers on (consumption ~0.5A), but no boot or display.
                • Fans spin briefly, keyboard backlight turns on, then fans stop.
                • Can be shut down via power button (EC active).
                • No POST, no BIOS splash, no backlight.
                • Led is blinking 2 orange 1 white
                • No activity on SPI bus (no CS#, no CLK, no MOSI/MISO) even after pressing power.
                • No APU_PCIE_RST# - 0V
                Measurements:
                • All voltage rails present: +1.8V, +0.75V, +3VS, +5VS, VDDCR_VDD, VDDCR_SOC, DDR VDDQ, VTT.
                • EC_RSMRST#
                06-26-2025, 11:47 PM
