Vostro 3401 strange problem charge
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    Now the one offering apologies is me, I was working on the bottom side, when I looked at this part that you pointed out, I noticed the marker that is above PQ1 and not in PL3. The aggravating factor is that it was on the inductive coil PL301 on the bottom side, regarding the resistor PR1=33.2 ohms on my multimeter
    the measurements of PQ1 are
    Source/Drain= 65.2k
    Source/Gate= 12.48k
    Gate/Drain= 73.5k
    • the Benninger
      • Nov 2022
      • 189
      • venezulan
      I have no way of knowing if pq1 is good or not so I have made the decision to change it, while the resistance PR1 is at its correct value, which leads me to think that it is pq1 that causes the source to disassemble when reconnecting.
      If you have anything else to add, I would be grateful; if not, we will just wait for the arrival of the components.
      • mon2
        • Dec 2019
        • 14201
        These are very low resistance readings for a good mosfet:
        Source/Drain= 65.2k
        Source/Gate= 12.48k
        Gate/Drain= 73.5k
        Each should be hundreds of k ohms or higher. One reason could be the influence of other parts on the part so best to remove and then test the same mosfet while it is on your workbench. If the resistance readings remain low, the part is indeed defective. Curious on the measurements of this mosfet that has been removed.
        reference reading:
        https://electronicsbeliever.com/how-...-defective/​
        • the Benninger
          • Nov 2022
          • 189
          • venezulan
          disassembled or out of the motherboard the readings were as follows
          Source/Drain=72k
          Source/Gate = 750M
          Gate/Drain = 1050M Click image for larger version
          • mon2
            • Dec 2019
            • 14201
            Reverse the meter leads and test source / drain but to me, this part is defective from the low resistance.
            Source/Drain=72k​
            • the Benninger
              • Nov 2022
              • 189
              • venezulan
              #26
              happy start of the week
              something happens that I don't know if it's normal, when the reading started (38Mhom) it increased until it reached 60Mhom, in a span of 1 minute. I think it would have continued to increase if I hadn't lost connection. It's difficult to keep the test probes on the pins when it's disassembled due to the shape and size.
              • the Benninger
                • Nov 2022
                • 189
                • venezulan
                #27
                hello I bring news around here, replace the PU301 in addition to PQ1, the new thing is that it is no longer heating, but the machine still does not turn on, not even the charging LED
                I made some readings that I attached in the image, when I made the mistake of incorrectly bridging on the coil (PL301) is when I immediately lost it, so the question is do you know which other component suffered from this?
                • Sephir0th
                  • Oct 2020
                  • 1282
                  Voltage measurements are usually less than half of the picture you need.
                  Measure resistance to GND of Pin 9, 11, 12, 17 and 20 and share the readings here.
                  PS: it's still puzzling how the PU301 has failed this bad. Normally nothing bad should happen when connecting a 3V supply to a signal which is supposed to be supplied with 3V too. At least not with such serious damage.
                  FairRepair on YouTube
                  • teccyber-lab
                    • Apr 2025
                    • 17
                    • BRAZIL
                    #29
                    Hi Sephir0th I'm writing from another account, I can't use my computer anymore. I decided to copy the client's data to my mother card, that's why I couldn't use my computer anymore. the sense of responsibility is very strong
                    While I did a reading of PU301 as you asked, I hope you can fix this Mobo because it would be the one I'm going to use. If I can fix it, of course, here are the results of the ground resistance measurements, and the voltage reading when the plava is energized. I await your guidance.
                    • mon2
                      • Dec 2019
                      • 14201
                      From pins 17 & 18 on PU301 - the +3VALWP is shorted.
                      Locate a solder blob @ PJP302. This blob shorts +3VALWP to +3VALW. Remove this solder short and then measure the resistance to ground on PL301. No power to the board during this test. Is PL301 still 10R9 ohms to ground?
                      • teccyber-lab
                        • Apr 2025
                        • 17
                        • BRAZIL
                        #31
                        hI mon2 I have the new readings
                        pin hom volts WIHTOUT-PJP302
                        1 1~1.5M 4.3 2.2M
                        2 500k 19.4 10M
                        3 500k 19.4 10M
                        4 500k 19.4 10M
                        5 500k 19.4 10M
                        6 10.9 9mv 44K
                        7 0.2 0 0.2
                        8 0.2 0 0.2
                        9 10k 105mv 54K
                        10 --- 125mv 0.L
                        11 125 462mv 130K
                        12 2k 457mv 1920K
                        13 0.75 330mv 0.670M
                        14 10.9 4.5mv 40K
                        15 10.9 179mv 40K
                        16 46k 6.6mv 47K
                        17 46k 6.6mv 155K
                        18 0.2 0 0.4
                        19 10.9 54~90mv 39K
                        20 10.9 54~90mv 39K
                        • mon2
                          • Dec 2019
                          • 14201
                          So the regulator is not shorted but downstream consumer side is. Measure the resistance from the solder blob to the pch 3v3 rail. The pch uses the same power rail. It is possible the cpu is dead from this event but to be determined.
                          • teccyber-lab
                            • Apr 2025
                            • 17
                            • BRAZIL
                            #33
                            Good morning mom2, I don't know how to reference PCH 3v3, don't have the boardview for this board, however I read the ground to everything surrounding PJP302, intuitively it takes me to UZ2
                            • mon2
                              • Dec 2019
                              • 14201
                              Pour some alcohol on the top surface of UZ2. This will enhance the markings. Then take a clear pic of the top surface. What are the markings? The very large PCB traces hints that the same rail is being shared by a device that consumes heavy currents. Where does this area lead to?
                              • teccyber-lab
                                • Apr 2025
                                • 17
                                • BRAZIL
                                #35
                                PU301 overheats
                                • mon2
                                  • Dec 2019
                                  • 14201
                                  Click image for larger version  Name:	PU301.png Views:	0 Size:	144.2 KB ID:	3694009
                                  If PU301 is overheating, remove all power. Meter in resistance mode. Measure the resistance to ground of each output rail on this device.
                                  • teccyber-lab
                                    • Apr 2025
                                    • 17
                                    • BRAZIL
                                    #37
                                    PIN ToGND
                                    1-BS 100k~141k
                                    2~5 210k
                                    6 10.7hom
                                    7+8 000.4
                                    9 9.90k
                                    10 900m
                                    11 110k
                                    12 1965k
                                    13 170k
                                    14 12.3hom
                                    15 0.960m~1500m
                                    16+17 1744hom
                                    18 000.2hom
                                    19+20 10.7hom
                                    • mon2
                                      • Dec 2019
                                      • 14201
                                      Can you confirm if the solder blob @ PJP302 is open or is it closed with solder?
                                      • teccyber-lab
                                        • Apr 2025
                                        • 17
                                        • BRAZIL
                                        #39
                                        close
                                        • mon2
                                          • Dec 2019
                                          • 14201
                                          Open this solder blob and confirm if the short remains on pins 19 & 20.
                                            DELL Vostro 3401 Notebook 3000 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3401 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3401 boardview and 3401 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3401 Notebook...
                                            09-07-2024, 12:40 AM
                                            09-07-2024, 12:10 AM
                                            09-06-2024, 09:30 PM
