Vostro 3401 strange problem charge
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    Now the one offering apologies is me, I was working on the bottom side, when I looked at this part that you pointed out, I noticed the marker that is above PQ1 and not in PL3. The aggravating factor is that it was on the inductive coil PL301 on the bottom side, regarding the resistor PR1=33.2 ohms on my multimeter
    the measurements of PQ1 are
    Source/Drain= 65.2k
    Source/Gate= 12.48k
    Gate/Drain= 73.5k
    • the Benninger
      • Nov 2022
      • 189
      • venezulan
      I have no way of knowing if pq1 is good or not so I have made the decision to change it, while the resistance PR1 is at its correct value, which leads me to think that it is pq1 that causes the source to disassemble when reconnecting.
      If you have anything else to add, I would be grateful; if not, we will just wait for the arrival of the components.
      • mon2
        • Dec 2019
        • 13837
        These are very low resistance readings for a good mosfet:
        Source/Drain= 65.2k
        Source/Gate= 12.48k
        Gate/Drain= 73.5k
        Each should be hundreds of k ohms or higher. One reason could be the influence of other parts on the part so best to remove and then test the same mosfet while it is on your workbench. If the resistance readings remain low, the part is indeed defective. Curious on the measurements of this mosfet that has been removed.
        reference reading:
        https://electronicsbeliever.com/how-...-defective/​
        • the Benninger
          • Nov 2022
          • 189
          • venezulan
          disassembled or out of the motherboard the readings were as follows
          Source/Drain=72k
          Source/Gate = 750M
          Gate/Drain = 1050M Click image for larger version
          • mon2
            • Dec 2019
            • 13837
            Reverse the meter leads and test source / drain but to me, this part is defective from the low resistance.
            Source/Drain=72k​
            • the Benninger
              • Nov 2022
              • 189
              • venezulan
              #26
              happy start of the week
              something happens that I don't know if it's normal, when the reading started (38Mhom) it increased until it reached 60Mhom, in a span of 1 minute. I think it would have continued to increase if I hadn't lost connection. It's difficult to keep the test probes on the pins when it's disassembled due to the shape and size.
              • the Benninger
                • Nov 2022
                • 189
                • venezulan
                #27
                hello I bring news around here, replace the PU301 in addition to PQ1, the new thing is that it is no longer heating, but the machine still does not turn on, not even the charging LED
                I made some readings that I attached in the image, when I made the mistake of incorrectly bridging on the coil (PL301) is when I immediately lost it, so the question is do you know which other component suffered from this?
                • Sephir0th
                  • Oct 2020
                  • 1258
                  Voltage measurements are usually less than half of the picture you need.
                  Measure resistance to GND of Pin 9, 11, 12, 17 and 20 and share the readings here.
                  PS: it's still puzzling how the PU301 has failed this bad. Normally nothing bad should happen when connecting a 3V supply to a signal which is supposed to be supplied with 3V too. At least not with such serious damage.
                  FairRepair on YouTube
                    DELL Vostro 3401 Notebook 3000 Specification for Upgrade or Repair
                    This specification for the DELL Vostro 3401 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3401 boardview and 3401 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3401 Notebook...
                    09-07-2024, 12:40 AM
                    09-07-2024, 12:10 AM
                    09-06-2024, 09:30 PM
