Acer Aspire A515-56 Main FH5AT LA-K093P no power
  • Egidio85
    • Jul 2019
    • 38
    • italia
    Hi everyone, I was looking for some advice on an Acer Aspire A515-56 with a FH5AT LA-K093P motherboard.
    the PC does not turn on, the battery is completely dead.
    checking the board I do not detect shorts.
    the 19v of the charger stops at the first mosfet PQB3
    on PUB1 BQ24781 pin 28 I have 19v.
    connecting with a bench power supply I have no absorption.
    nothing that heats up with a thermal camera.
    any advice on what to check?
    thanks in advance​
  • mon2
    • Dec 2019
    • 14256
    Hi. Yes, review the detailed sticky article above by piernov on charger circuits.
    Remove all power. Meter in resistance mode.
    Measure the resistance across the first DCin mosfet:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement. Each measurement must be hundreds of k ohms or higher else could be shorted. Repeat for the 2nd DCin mosfet.
    Also check the resistance to GROUND of the 2nd DCin mosfet - test the source (1-2-3) pins and also the drain pins (5-6-7-8). We are checking this to confirm the final output of these DCin mosfets is not shorted for the main power rail which may be the reason for the damage of the DCin mosfets.
    Being N-channel mosfets, the gate pin of both DCin mosfets should be = adapter_voltage + REGN voltage = ~25v to fully enable.
    • Egidio85
      • Jul 2019
      • 38
      • italia
      thanks for the reply, here is the measurement
      first mosfet PQB3
      source (1-2-3) & drain (5-6-7-8). 67K ohm
      source (1-2-3) & gate (4). 85K ohm
      1.2M ohm
      second mosfet PQB4
      source (1-2-3) & drain (5-6-7-8). 800K ohm
      source (1-2-3) & gate (4). 600K ohm
      800K ohm
      second mosfet PQB4
      gnd source (1-2-3)​ 110K ohm
      gnd drain (5-6-7-8). 6K ohm
      • mon2
        • Dec 2019
        • 14256
        Flux and replace the first Dcin mosfet at PQB3.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          DC jack often fails on this board blocking 19V.Check it to be sure.
          • Egidio85
            • Jul 2019
            • 38
            • italia
            changed the first mosfet. same situation, behavior does not change
            • mon2
              • Dec 2019
              • 14256
              Click image for larger version  Name:	IMG_4748.jpg Views:	0 Size:	44.5 KB ID:	3647218
              Which mosfet was used for the replacement? With no power, share the same resistance checks for this new mosfet.
              Then, attach the power adapter and carefully measure the voltage to ground for the following pins:
              Using BQ24780S as reference which is with the same pinout -
              REGN
              VCC
              ACDRV
              ACOK
              Also ACDET.
              • mon2
                • Dec 2019
                • 14256
                As per post #5 - confirm the attached which may be the root cause. We have seen this a few times on this forum.
                In summary - the ADAPDET pin on the power connector is failing to provide the 0V or GROUND. Respectively, the ACDET voltage is then pulled to ground due to the mosfet @ PQ101.
                As a test, you can connect a piece of wire to the gate pin of PQ101 to GROUND which will force PQ101 to DISABLE. Then ACDET should follow a voltage suitable to enable the mosfets.
                Click image for larger version  Name:	adapdet.png Views:	0 Size:	78.4 KB ID:	3647314
                • Egidio85
                  • Jul 2019
                  • 38
                  • italia
                  Thanks for the advice, by putting pin number 2 of the PQ101 to ground the PC started working again. Can I leave it like this? Or could it cause problems?
                  • mon2
                    • Dec 2019
                    • 14256
                    You can leave this wire jumper and use the laptop like normal. The root cause is as noted by mcplslg123, the dcin power adapter connecter is likely loose for this pin that should have pulled this mosfet gate pin to ground.
                    The manual wire jumper now performs the same task.
                    • Egidio85
                      • Jul 2019
                      • 38
                      • italia
                      ok, thank you so much for your help
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Wiser to replace the DC jack as it already shows signs of failure. Why risk it?
                          ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-12-2024, 03:36 PM
                          ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-12-2024, 03:30 PM
                          ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          ACER Aspire Aspire Revo R3600 Aspire 230 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire Revo R3600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire Revo R3600 boardview and Aspire Aspire Revo R3600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-12-2024, 03:28 PM
                          ACER Aspire Aspire X1301-L Aspire 215 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire X1301-L can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1301-L boardview and Aspire Aspire X1301-L schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
