MacBook Pro A2338 won't start
  • Nobuto Matsuda
    • Apr 2025
    • Japan
    I am trying to repair my Macbook A2338 820-02020.
    I was able to narrow down the cause to some extent, but I don't have any conclusive evidence to identify the cause, so I would appreciate any advice.
    Here is what I did:
    When I plugged in the power, the voltage rose to 20V, but there was no change after that, and the CPU did not appear to be working.
    I tried to revive it in DFU mode with APPLE Configurator, but it stopped with an error halfway through.
    It probably failed when starting the CPU to write.
    I measured the power supply of the board, and found that
    PPDCIN_USBC_AON was 20V, but
    PPBUS_AON was only 12V. The normal voltage is 12.6-13.1V, so it is very low.
    According to repair.wiki, if it is 12.28-12.35V, it is a problem with the communication between the SOC and PMICs,
    but the voltage is lower than this range.
    The other power rails seem fine.
    PP3V8_AON 3.8V
    PP3V3_S2 3.28V
    PP5V_S2 5.17V
    PP3V_S2_UPC 3.29V
    PP1V25_S2 1.22V​
  • mon2
    • 14662
    Confirm the voltage rails for the NAND flash devices:
    PP2V5_AWAKE_NAND
    • Nobuto Matsuda
      • Apr 2025
      • Japan
      Thank you for your advice.
      I measured PP2V5_AWAKE_NAND.
      It was 2.53V.​
      • Orux
        Macbook Pro M1 A2338 13"
        by Orux
        I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
        I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
        One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
        09-22-2025, 12:54 PM
      • sdogs
        macbook pro M1 a2338 no video on internal display PP3V3_S2 short
        by sdogs
        Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
        First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
        I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
        06-27-2025, 01:58 PM
      • sdogs
        by sdogs
        06-27-2025, 11:26 AM
      • classicandy
        MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
        by classicandy
        Hi Everyone,
        Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
        UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
        04-14-2024, 12:00 PM
      • User555111
        A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
        by User555111
        Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
        02-05-2024, 08:16 AM
