Alienware Area-51M R1 no power
  • Jasonexe
    • Apr 2023
    • 69
    • Belgium
    Long story: This laptop originally had a issue with a bricked bios because of downgrading and since then it did not want to work anymore. After some searching i found a bios dump of someone else their bios and i flashed it on my laptop with a CH341A programmer (volt modded to 3.3v) and i got it to work again.
    I decided to downgrade the bios again (with recovery method) but ended up getting the same result. This time when i reflashed the chip it still refused to work. I also tried to flash the EC chip (W25Q80DVSIG) but no success. When trying to power on the laptop, it cycles with a green light on the power button for a couple times and after it gives me 2 red flashes followed by 1 blue flash which means cpu failure. I confirmed that the cpu is 100% working in a other system so it must be something else.
    I checked resistance from the power delivery rails of the cpu but did not see anything abnormal. However, when i try to program the bios IC (W25Q128JVSQ) with a clip connected to it i noticed that one specific corner of the chipset gets hot, so does my programmer. At this point i'm not sure if this is normal or did the chipset gave up on me?
    System specs:
    Motherboard: LA-G881P REV 1.0
    i7-8700
    RTX 2060
    2x16GB DDR4 2666V
    Kingston KC3000 1TB
    Samsung EVOPLUS 970 2TB
    1TB HDD Firecuda
  • drux
    Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
    by drux
    I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
    Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
    These models have AMI/Aptio BIOS.
    Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
    11-03-2024, 01:18 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • iulik17d
    Intel Arc A380 videocard power limit remove - BIOS needed
    by iulik17d
    Hello everyone!
    The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
    The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
    01-10-2025, 02:33 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
    by Vesko356
    08-11-2023, 03:27 AM
