HP 11 Stream laptop DAYOHGMB6C1 REV:C doesn't show video at all!
  • alro7779
    Alex
    • May 2025
    • 32
    • Mexico
    Hello, there!
    The problem with this laptop is that it does not show video at all, even if I connect an external HDMI screen device to its port.
    I got it disassembled, and first of all it does have its VDC in (19.81). I checked the 5 inductors having the charger plugged in, and the voltage readings are:
    TURNED OFF (without pressing the power button)
    1: 9.07 VDC
    2 to 5: 0 VDC
    TURNED ON (after pressing the power button)
    1: 9.04 VDC
    2: 1.203 VDC
    3: 0.813 VDC
    4: 3.403 VDC
    5: 5.133 VDC
    I'm not quite sure if the reading of the third inductor is fine or not. Hope you guys can guide me on this. I don't know what else to check.
    Thanks in advance!
    Alex.
  • alro7779
    Alex
    • May 2025
    • 32
    • Mexico
    Is this post in the wrong place or some? 39 views and no response? 🤔
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Refrain from making such comments for 2 reasons:
      01.This is not a paid service
      02.All of us are busy and live in various parts of globe with different time. zone
      Measuring voltage on coil is not sufficient for no display issues, you need to dig a lot deeper.
      M_A_DRAMRST# present?
      Bios flashed?
      Schmeatic is available in this forum-so start digging .
      • alro7779
        Alex
        • May 2025
        • 32
        • Mexico
        Sorry about that comment of mine, I felt just kinda frustrated for not having response. Won't happen again.
        I'll do that!
        I don't know where is located to check. Couldn't find the schematics (maybe I need to dive deeper).
        Bios flashed?
        Not yet, but I'm going to; need to get the programmer first.
        I've already started trying to find it when I came here. If you say it is here, then I'll have to try to find it again.
        Thanks in advance!
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Schematic here
          https://www.badcaps.net/forum/troubl...need-schematic
          • alro7779
            Alex
            • May 2025
            • 32
            • Mexico
            There's no memory modules on this model, it's soldered chips.
            • mon2
              • Dec 2019
              • 14120
              The soldered ram chips will also feature a reset line. The '#' suffix denotes that the signal is active LOW. This means when the line is LOW, the target device is parked in the reset state. To run normally, the same line must be released to the logic '1' or high state and is often ~3v3.
              • alro7779
                Alex
                • May 2025
                • 32
                • Mexico
                I just learned something new. Thank you, dude. I'll try to check those lines, and I'll post the measuring.
                • alro7779
                  Alex
                  • May 2025
                  • 32
                  • Mexico
                  Thank you a million times, dude!!! 😀
                  • alro7779
                    Alex
                    • May 2025
                    • 32
                    • Mexico
                    Took a screenshot from the schematic where it shows one of the memory slots plus a small rectangle with 4 pins at the bottom, which I suppose it corresponds to the soldered chips I have (4 at the front and 4 at the rear); each one of them of 8 Gb, as you can read in the picture. Also, I'd like to share a picture of the mainboard so you can help me where I should check those lines you previously said? I can notice some check points there, and also the printed numbers 1,2,3 and 7,8,9, by the chips.
                    Thanks in advance!
                    Alex.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Correction to post#7-It is often 1.35V for DDR3-L and 1.2V for DDR4 and not 3.3V
                      • alro7779
                        Alex
                        • May 2025
                        • 32
                        • Mexico
                        Thanks for the info, dude!
                        I flashed the BIOS using two different .bin files a friend shared with me, but it didn't work, so I'm gonna use one from here (once I have one). I'll be posting the results here.
                        Cheers!
                        • m1ch43lzm
                          • Mar 2019
                          • 401
                          • Peru
                          https://www.badcaps.net/forum/troubl...c1-rev-c/page2
                          Board model in your case is DAY0HGMB6C1, a zero instead of letter O
                          If flashing the BIOS doesn't work then if you're lucky you can find a working board for cheap like this one
                          https://www.ebay.com/itm/256253333379
                          As some sellers want more money than the cost of the same laptop second hand in working condition
                          • alro7779
                            Alex
                            • May 2025
                            • 32
                            • Mexico
                            So far, I've been using various .bin files (up to 4 as of yet) to flash my BIOS, but none of them have worked! I even used one for the laptop model HP Stream 11 Pro G5 Notebook PC, since a user mentioned in another thread that worked successfully for the HP Stream 11-ah117wm. And, another problem just arrived... now the power led is not working when I plug in the charger! I checked the 19.81 VDC in the power connector of the board, and it's present.
                            • alro7779
                              Alex
                              • May 2025
                              • 32
                              • Mexico
                              I can't afford buying the board, which may be cheap there, but not here in Mexico, to fix the problem. Also, I'd like to, at least, find out what is bad in the laptop so I can tell to the client... or keeping trying to fix the problem.
                              • alro7779
                                Alex
                                • May 2025
                                • 32
                                • Mexico
                                Been looking for the boardview, but can't find it; I need to check some areas with no voltage by two of the inductors.
                                After the BIOS flashing process, the problem got worse since now the power led is dead. Since it has two LEDs (amber and white), I tested both using a multimeter on diode function, and it only lit the amber one (the positive lead on the pin 3 and the negative on the pin 1). Did the same with the white led (the positive lead on the pin 3 and the negative on the pin 2), but it does not light up. In both cases, the voltage measured was 1.8 vdc. However, if I check the diodes independently, both have .490 vdc. Even though, when I plug in the charger it does not show the white led. Strange. I wonder how that LED went bad after flashing the BIOS.
                                • m1ch43lzm
                                  • Mar 2019
                                  • 401
                                  • Peru
                                  Haven't found schematics/boardview for your exact board, here's a similar one you can use for reference
                                  https://www.badcaps.net/forum/troubl...wm-da0y0hmb6f0
                                  It's for the previous generation of HP stream 11, CPU and RAM are different, yours has N4000 CPU and DDR4 RAM, the one I linked has N30xx CPU and DDR3L RAM
                                  The I/O board with audio and USB port is the same though
                                  • alro7779
                                    Alex
                                    • May 2025
                                    • 32
                                    • Mexico
                                    Thanks for your response, bro!
                                    Checking the mainboard more closely, I could detect a few capacitors shorted. I don't have experience with fixing computers on a component level, so I wonder how should I proceed in order to find the responsible for the short.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      The circled caps are not likely shorted . They are part of cpu vcore circuit and low resistance to gnd is expected there.
                                      Without boardview, its not possible to dig deeper-so yeh tough to crack it.
                                      • alro7779
                                        Alex
                                        • May 2025
                                        • 32
                                        • Mexico
                                        OK, bro, thanks for telling me that. And yes, as you said, without the boardview is gonna be very difficult to dig deeper. 🙄
                                          HP Stream Stream 14 Pro Notebook PC Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Stream Stream 14 Pro Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Stream 14 Pro Notebook PC boardview and Stream 14 Pro Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 06:40 AM
                                        • alro7779
                                          HP 11 Stream DAYOHGMB6C1 REV:C need schematic!
                                          by alro7779
                                          Hello, there!
                                          I have this HP 11 Stream laptop with the printed model on the back totally unreadable. I'm looking for the schematic since there's a problem with the video. The model on the main board is:
                                          DAYOHGMB6C1 REV:C
                                          I'll create a new post describing the problem I have with that laptop so you can help me to fix it. OK?
                                          Thanks in advance!
                                          Alex.
                                          05-15-2025, 08:08 PM
                                          HP Stream Z2 SFF G5 Workstation Stream i7-10700 Specification for Upgrade or Repair
                                          This specification for the HP Stream Z2 SFF G5 Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stream Z2 SFF G5 Workstation boardview and Stream Z2 SFF G5 Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:00 PM
                                        • alro7779
                                          Need bios for DAYOHGMB6C1 REV C HP Stream 11-ah117wm
                                          by alro7779
                                          Hello, there!
                                          I just flashed my mobo using two BIOS files a friend shared with me, but none of them worked. If anyone could share a working BIOS for my laptop, I'd greatly appreciate it. Here's my BIOS backup in the attachments.
                                          Thanks in advance!...
                                          05-29-2025, 08:32 PM
                                          HP Stream 14-ds0015nf Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Stream 14-ds0015nf Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-ds0015nf boardview and 14-ds0015nf schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 07:50 PM
