i have msi a15 b7ucx reboots on process of installation of widows 10 or 11 i tried also windows to go still keeps rebooting sad face stopcode error kernel security check failure etc. i already flash latest bios i still cannot install proper windows on my laptop.can someone can help me about this one
MSI A15 B7UCX restart on process of windos installation help
by shouriHi guys, can someone help me?
I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
Board model is dm70 la-f401p rev:1.0 2017-09-20.
At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
After a few days test, is seems ok.
Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same.... -
by YOUCEF4787I am writing to seek assistance regarding a problem I encountered while attempting to install the AMD Radeon 520 graphics drivers on my Dell Inspiron 15 3576 laptop running Windows 10.
Upon installing the graphics drivers, my system freezes, and I am left with a black screen. Unfortunately, this issue has prevented me from utilizing the full capabilities of my AMD Radeon 520 graphics card.
Laptop Model: Dell Inspiron 15 3576
Operating System: Windows 10
Graphics Card: AMD Radeon 520
Steps I have taken:
Downloaded the latest AMD...07-08-2023, 05:23 AM -
by duwaneHi All.
Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
The issue:
Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,... -
by DynaxSCHi,
I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
The behaviour is also really very strange, i.e.:- The disk shows always up in BIOS - so it is recognized, so far so good
- POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
Hello
The PC starts and shuts down correctly when the battery is removed. However, if I hot-plug the battery, it starts charging as if everything is normal. However, when I turn off the computer and then restart it, there is no display on the screen. The battery indicator blinks slowly, the fan runs, and the power consumption is approximately 520 mA, as if the computer is in standby mode. At this point, even if I disconnect the power supply, the computer doesn't start up normally anymore. Pressing the power button to force a shutdown works, but as soon as I release the button, the... - Loading...
