Aspire E1-531 charging problem, please help.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Hello everyone, Acer e1-531 have charging problem.it show plugged in charging but no charge save in battery. i have changed bq25a charging chip and 2 charging page mosfet but also same. i need expert help for solve it. please....
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Aspire E1-531 charging problem, please help.
    Are pq12 pq13 ok?????????
    Charging circuit(bq24725 or bq24728 or bq24738 or bq24735) is drive in this case by ec kb930 or 9012 .(sda scl )
    flash the bios first .
    • nazrul145
      • Jan 2014
      • 337
      • BD
      thanks for reply, but i already reflashed bios. pq12 an pq13 is ok.
      • aanan
        • Dec 2010
        • 222
        • India
        check PR52 .
        check BATT+ path [track] resistance.
        post pu4 all pin voltages.
        • alihomee
          • Dec 2012
          • 1591
          • malaysia
          change the battery
          • nazrul145
            • Jan 2014
            • 337
            • BD
            Thanks aanan for reply me. Here oi charging chip input voltage.
            pin 1=18v
            pin 2=18v
            pin 3=0.02v
            pin 4=18v
            pin 5=0.03v
            pin 6=2.4v
            pin 7=0.22v
            pin 8=3.3v
            pin 9=0.03
            pin 10=.75v
            pin 11=10.21v
            pin 12=10.27v
            pin 13=10.28v
            pin 14=0
            pin 15=0
            pin 16=6.04
            pin 17=0.13
            pin 18=10.03
            pin 19=10.27
            pin 20=18.8v
            • dj_ricoh
              • 2073
              • uk
              on pin 18 HIDRV(DH_CHG) you got 10v check the resistor PR50 if its ok and its enabling the gate to pq12 pin4
              and LODRV(DL_CHG) has 0 that's the gate for pq13 pin 4.
              • aanan
                • Dec 2010
                • 222
                • India
                check 18 voltage on pq12 pin no 5 6 7 8 .
                check pq12.
                check resistance pl4 to gnd.
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  those are correct measurement
                  Measure → V(TP(ACDET)) = 2.6 V ± 0.1 V
                  Measure → V(TP(ACOK)) = 3.3 V ± 0.1 V
                  Measure → V(J2(SYS)) = 19.5 V ± 0.5 V
                  Measure → V(TP(REGN)) = 6 V ± 0.5 V
                  Measure → V(TP(ACDRV, CMSRC)) = 6 V ± 0.5 V
                  Measure → V(J2(BAT, GND)) = 2 V ± 2 V
                  from yours
                  ACOK is not good pin 5 =0.02v must be 3.3v
                  pin4(acdrv)-pin3(cmsrc)=6v in your case pin4-pin3=18-0.03=18v so it is not good
                  ACDRV must be 24V or 25V and CMSRC 18v or 19V
                  24-18=6V and 25-19=6V (correct voltage )
                  • dycc
                    Vision
                    • Nov 2011
                    • 625
                    • Côte d'Ivoire
                    if those mentionned above are not find battery will not charge.
                    • nazrul145
                      • Jan 2014
                      • 337
                      • BD
                      Sorry some mistake find first input, now it is correct input with battery inserted
                      pin1=18.3v
                      pin2=18
                      pin3=19.05
                      pin4=19.08
                      pin5=3.18
                      pin6=2.4
                      pin7=0.13so
                      pin8=3.3
                      pin9=3.3
                      pin10=.73v
                      pin11=10.16
                      pin12=10.23
                      pin13=10.2
                      pin14=0v
                      pin15=0
                      pin16=6.04
                      pin17=10.14
                      pin18=10.01
                      pin19=10.2
                      pin20=18.03
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        pin1=18.3v
                        pin2=18
                        pin3=19.05
                        pin4=19.08
                        pin5=3.18
                        pin6=2.4
                        pin7=0.13so
                        pin8=3.3
                        pin9=3.3
                        pin10=.73v
                        pin11=10.16
                        pin12=10.23
                        pin13=10.2
                        pin14=0v
                        pin15=0
                        pin16=6.04
                        pin17=10.14
                        pin18=10.01
                        pin19=10.2
                        pin20=18.03
                        pin4-pin3=0V can't charge
                        check for continuity and also replace the 3 mosfet N type 4466 even if they seem to work.
                        • nazrul145
                          • Jan 2014
                          • 337
                          • BD
                          Thanks Lot everyone,specially dycc. i found pq9 mosfet is low resistance and change it now charging is ok. Many many thanks to everyone for help me.
                          • dycc
                            Vision
                            • Nov 2011
                            • 625
                            • Côte d'Ivoire
                            good .
                            • nazrul145
                              • Jan 2014
                              • 337
                              • BD
                              you are welcome..
                              • shijeesh
                                • Mar 2011
                                • 65
                                I have also this type problem in Aspire E1-531 can not charge and cannot trigger with ac adapter, Only ON battery through.
                                • shijeesh
                                  • Mar 2011
                                  • 65
                                  I need dycc your help, Please help me.
                                  • Andyd1970
                                    • Feb 2013
                                    • 374
                                    • united kingdom
                                    Hi Guys,
                                    Are any of you able to help with my post about a dead toshiba c650? I do not seem to be getting anywhere with it and really need to get it working.
                                    Thank you.
                                    • ghojariya abdul
                                      • Jul 2014
                                      • 39
                                      • india
                                      hi guys ,
                                      please give me a dump bios for this laptop
                                      i think this problame is sovled by bios only.
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1489
                                        • portugal
                                        BQ738 can bve replaced with a BQ728 ?
                                        • Scoff
                                          HP Probook 470 G4 - Power and Charging Problem
                                          by Scoff
                                          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                          07-03-2023, 09:28 AM
                                          ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:36 PM
                                          ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:30 PM
                                          ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:28 PM
