inspiron 3521 ISL95833 +VCC_CORE ok, But no +VCC_GFXCORE_AXG.
  • nazrul145
    • Jan 2014
    • 339
    • BD
    Hello brothers, now i have problem with dell inspiron 3521. first time it has no display. i check vcc core and graphics core missing. i have changed isl95833hrtz, now VCC_CORE is ok but no +VCC_GFXCORE_AXG found. Please help me why graphics core missing.there is no short in PL700 and PL701. is isl95833 is bad?????? or which voltage is recquired for enable graphics core.
    P/N: LA-9104P
    Last edited by SMDFlea; 02-26-2021, 06:13 AM. Reason: added inspiron 3521 to thread title
  • dellxps15
    • Feb 2014
    • 1600
    • italy
    Re: ISL95833 +VCC_CORE ok, But no +VCC_GFXCORE_AXG.
    what voltage on pq700, pq702 and pq703 ?
    • nazrul145
      • Jan 2014
      • 339
      • BD
      only pq700 pin 5,6,7,8 have 18v and oter pin have no voltage
      • dellxps15
        • Feb 2014
        • 1600
        • italy
        check voltage on pl800 when power on, and without power supply and battery if it's shorted.
        i think that vccgfxcore is the voltage that tell the isl95833 that vga is ok and that can turn on vcc core... infact on page 53 is vga power while on page 52 it's vcc core
        • nazrul145
          • Jan 2014
          • 339
          • BD
          Thanks dellxps15 to reply me. but this motherboard have no pl800.
          • dellxps15
            • Feb 2014
            • 1600
            • italy
            it should be near pu800 check pq802 pin 5-6-7-8
            • iamkamalrandhawa
              • Dec 2013
              • india
              Check with an magnifier the legs of changed ic are soldered correctly ?
              • nazrul145
                • Jan 2014
                • 339
                • BD
                i have another same board inspiron 5521 which have amd graphics thats why its need pl800. But this motherboard only have intel graphics and no amd gpu so its pl800 place is blank. i removed and resolder this chip. but same. thanks for reply me......
                • GLogic
                  • Jan 2015
                  • india
                  [QUOTE=nazrul145;466481]Hello brothers, now i have problem with dell inspiron 3521. first time it has no display. i check vcc core and graphics core missing. i have changed isl95833hrtz, now VCC_CORE is ok but no +VCC_GFXCORE_AXG found. Please help me why graphics core missing.there is no short in PL700 and PL701. is isl95833 is bad?????? or which voltage is recquired for enable graphics core.
                  P/N: LA-9104P[/Q
                  HTML Code:
                  Dear i have dell inspiron 3521, i facing same problem no vcc core & vcc gfxcore voltage. as per schematic diagram there is
                  1) VR_ON enable signal is available ie 3.3v
                  2) VDD voltage available ie 5v
                  as per concept ISL95833 should generates VCC CORE & VCC GFXCORE but this two are MISSING.
                  Mr. Nazrul please suggest me what to do.
                  whether i need to change ISL95833, but still i have not replaced it. because above voltages are present.
                  • nazrul145
                    • Jan 2014
                    • 339
                    • BD
                    Replce chip with working one.
                    • whitejohnny71
                      • Mar 2010
                      • 26
                      I am working on this same board. You should also check the high side fet PQ700, mine was shorted. Same symptoms. I havent replace the ISL95833HRTZ yet.
                      • alibisma
                        • Oct 2014
                        • 37
                        • Saudia
                        hi guys i have a problem with dell 3521 m-board 2 beeps i will try all thing change ram but still there plz help
                        • surajndsbadcaps
                          • Dec 2013
                          • 5
                          • nepal
                          hi guys
                          I have a la-9104, Its all ok but VR_On power is not appearing, somebody shoutout this problem, plz help!!!!!!!!!!!
                          • surajndsbadcaps
                            • Dec 2013
                            • 5
                            • nepal
                            VR_ON doesn't appear on pin no 2 of the ISL95833 then the +VCC Core and GFX Core also zero, is somebody has fixed? .......
                            • kiraro
                              • Jan 2016
                              • 177
                              • North NY
                              Check there is a short on B+ or not .
                              • surajndsbadcaps
                                • Dec 2013
                                • 5
                                • nepal
                                Dear Kirro, There is no any B+ short.......
                                • tomodachi
                                  • Apr 2012
                                  • 621
                                  • Turkey
                                  desperate with same exact issue here.. VR_ON missing
                                  • HarryPK
                                    • Mar 2014
                                    • 212
                                    • barabai
                                    its look like missing signal. +VCC_GFXCORE_AXG is on if all signal is good. search the power sequence path.
                                    • HarryPK
                                      • Mar 2014
                                      • 212
                                      • barabai
                                      is there any missing pqwer rail?!
                                      • marouen92
                                        • Dec 2017
                                        • tunisia
                                        i have the same problem on dell 3521,no vcc core pl700 & pl701 shorted to ground what can i do?
                                        "The Quieter You Become The More You Can Hear"
                                        • jasonbay13
                                          Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
                                          by jasonbay13
                                          it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
                                          PU200
                                          pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
                                          pin 8 vreg3 = 0v
                                          pin 13 en = .2v
                                          pin 1,6 entrip1,2 = 0v
                                          b+ and b++ = 19.5v
                                          +5valw = 0v & 25+ohm to ground
                                          +3valwp = 0v & 25+ohm to ground
                                          i cleaned the board up just a little and can get more pics.​
                                          where should i be looking? thx...
                                          09-25-2025, 10:54 PM
                                          DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Inspiron 3650 Inspiron i3-6100 Specification for Upgrade or Repair
