Hp pavillion x360 15-CR0087CL BOARD: LEIA_15 KBL UMA 17881-1B missing component
  • jagg
    • Feb 2012
    • 30
    • Mexico
    Hello friends, I have this laptop which would not turn on, I detected that the 3v and 5v source circuits were damaged and a 6 pin circuit in short, which I suppose are diodes, I'm not sure since there is no diagram, I removed this circuit and the sources and there is no longer a short, the new 3v and 5v sources were installed and the laptop now works, the problem is that I don't know what this 6-pin circuit is, I think it has to do with the battery, since the operating system does not detect the battery, I measured the IC pins and they go to these pins of the battery connector, does anyone know what type of circuit it is? I lost the original circuit and I no longer have it to see the license plate, any idea what replacement circuit I can install ? thank you !!
  • mon2
    • Dec 2019
    • 14742
    Very good repair. The part indeed will be a SOT23-6 packaged ESD TVS diode array with a rating of 3v3 to 5v max. The focus of this part is to prevent transients on the SMBUS lines. If this part was originally shorted then it appears to have done the job.
    From where do you purchase your parts? Digikey? Mouser?
    • jagg
      • Feb 2012
      • 30
      • Mexico
      Thanks for the tip, I already got the circuit, I already tested it, but it's still the same, it doesn't recognize the battery, it doesn't detect it, I'll keep checking.
      The parts are from AliExpress
      • mon2
        • Dec 2019
        • 14742
        Measure the voltage to ground on each of the battery pins. The key ones are the SMBUS pins (SCL / SDA) used by the SMBUS master to extract the details of the battery pack. Do test with another known good battery (Amazon?). It is possible the original battery under test is locked. If the SMBUS lines (SCL or SDA) are stuck then the battery pack will not be detected.
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
        • Tarot Superstars
          Short Circuit tester
          by Tarot Superstars
          Hello.
          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
          Link
          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
          https://www.youtube.com/watch?v=0eixDdCpiO4
          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
          09-25-2023, 09:11 AM
        • Alimash
          op amp circuit function?
          by Alimash
          I am repairing a ups which doesn't turn on ,it has the following ICs:
          SG3525 used to drive inverter mosfets.
          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
          A LM358 and TL074 for control mechanism and of course the uController.
          The SG3525 is shutting down every time the ups is turned on.
          I want your help to know the function of LM358 and TL074 in the system.
          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
          07-31-2025, 07:45 AM
        • M1NEBLANK SHOW
          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
          by M1NEBLANK SHOW
          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
          Schematic and Boardview here
          04-04-2025, 03:57 PM
        • прямо
          Viper22A 5VSB circuit
          by прямо
          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
          01-13-2024, 07:05 PM
