Lenovo Ideapad 3 won't start
  • Antonio Distefano
    Il Tecnico
    • Apr 2025
    • 7
    • IT
    have a Lenovo V15 ADA05 laptop that fails to power on. I've already tried several troubleshooting steps, including replacing the RAM, running hardware tests, performing a BIOS reset, and even reflashing the BIOS firmware.
    When I press the power button, the power LED blinks briefly, the fan spins up momentarily, then stops — and the system remains unresponsive with no display output.
    What could be the potential cause of this issue?​
  • mon2
    • 14673
    Hi. What is the history of this unit?
    Issue could be a defective onboard capacitor that is showing a short condition and this event is forcing the local power rail to power down. The name of this website is built upon 'bad caps'.
    Perhaps an issue in the power path from the power adapter to the main power rail. With a multimeter we can assist to diagnose the defective part(s) onboard. Would you have one for taking a few measurements?
    • Antonio Distefano
      Il Tecnico
      • Apr 2025
      • 7
      • IT
      Hi there, my friend. Honestly, I had a quick look with a multimeter at some components and fuses, but I'm not very familiar with reading schematics.
      Maybe you could give me a hand with that.
      This laptop stopped working all of a sudden — I initially thought it was just a dead battery because the power LED was blinking, so I assumed it was just low charge.
      I tried resetting the BIOS and replaced the battery, and surprisingly it worked again for about a week.
      But then it completely stopped powering on and hasn't turned on since.
      • mon2
        • 14673
        I am guessing that it worked for a week since you replaced the battery. The battery had a pre-charge and the unit ran off the battery. The hints are going back to the common fault of the power path. The power adapter (assuming it is ok and often it is), will mate with DCin mosfets which act like solid state relays to pass the power onto the main rail. If there is a faulty mosfet (usually there are 2 in series), then the battery will not charge. This is why you ran for a week ok, it was all on battery mode only.
        We need a good view of the board to hunt for the battery charger IC and the local 2 x DCin mosfets. Then with your multimeter, you can confirm which part is defective. You mentioned that you have a multimeter?
        • mon2
          • 14673
          Start with locating the DCin power adapter connector. Share clear pics of the region. Here we can confirm the voltage from the power adapter is actually reaching the logic board parts. Following this check will be the DCin mosfets.
          If the voltage on the gate pin of each mosfet is high enough, only then will the power adapter voltage travel onto the main power rail. We know that you were able to run the unit from battery for a week so very likely the fault is pre-charger region. There is a very good article (sticky) above on charger circuits by piernov. A good sedative with solid information.
          Using the meter, without power to the board, we can test the mosfets which are the current suspects for your case. Moving forward, you can order the mosfets and have a local cellphone repair shop replace the parts or lean on a local EE student from your college / university who probably will have the tools (and a propeller cap).
          • Antonio Distefano
            Il Tecnico
            • Apr 2025
            • 7
            • IT
            I actually have a full lab setup at home, so I could definitely handle the repair myself.
            I already do soldering work and similar tasks — I usually handle PC and console maintenance, mostly on the software side, but I haven't done much hands-on work with schematics before.
            That said, if we can identify the faulty component together, I'm confident I can replace it myself.
            I'm not at home right now, but once I bring the laptop back to my lab, I'll inspect the board and send you some clear photos of the area around the DC-in connector and nearby components.
            Thanks again for the support — I'll update you in a few hours!
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I'll bet more on cracked solder joints under SOC. This is the most common fault on newer lenovo's due to "Low Melting Solder"
              • Antonio Distefano
                Il Tecnico
                • Apr 2025
                • 7
                • IT
                So, thake a look guy
                • Antonio Distefano
                  Il Tecnico
                  • Apr 2025
                  • 7
                  • IT
                  Wich one? is this common?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Yes, its very common for newer lenovo's to have cracked solder joints under SOC. the reason is solder used by lenovo.It melts at very low temparature compared to other brands.
                    So when the SOC heats up, the balls gets cracked underneath-A very usual feature with lenovo's.
                    I'm betting on this 'coz you have intermittent display. If you have BGA machine try to reflow it a bit(dont use hot air gun).
                    However, if my doubt is correct,then reflowing wont fix your issue as there is black glue underneath SOC. It needs reballing and thats not easy.
                    I just highlighted one of the major reason for failure in lenovo's.Your case may be different-so keep digging.
                    • Antonio Distefano
                      Il Tecnico
                      • Apr 2025
                      • 7
                      • IT
                      mcplslg123 I don't have the equipment for a full SoC reball — I only have a hot air station, not a dedicated reballing machine.
                      That said, I do have a preheater, a hot air station, and the standard tools I use regularly for hardware work.
                      Maybe before going that far, mon2 could help me do some basic diagnostics using the multimeter, beyond what I've already checked.
                      I'm still new to working with schematics — I've never really had to follow them before — so I'd definitely appreciate some guidance.
                      • Dr.d
                        Help please..Lenovo ideapad 5 14itl05 power and charging problem
                        by Dr.d
                        I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                        Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                        04-05-2024, 11:48 AM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • gleniu
                        Lenovo IdeaPad Gaming 3 15ACH6 - no power
                        by gleniu
                        Hi, I have a problem with a Lenovo IdeaPad Gaming 3 15ACH6 laptop. My nephew asked me to replace the charging port because the laptop wasn't charging. This issue had happened in the past, so I knew that replacing the port was only a matter of time. Until now, my nephew managed to deal with the problem using a temporary solution: bending the positive metal tabs inside the port with a thin tool. However, this had stopped helping for a while. Today, I replaced the port – and to my surprise, after the replacement, nothing happens when I plug in the charger: the power LED doesn't light up, the laptop...
                        10-27-2025, 01:13 PM
                      • rabsonnjala
                        LENOVO IDEAPAD 100 works only on bench power supply
                        by rabsonnjala
                        Hie I have a Lenovo laptop
                        Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                        it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                        below are my readings
                        with the original charger only
                        JBATT1
                        PIN1 0.22V
                        PIN2 0.22V
                        PIN3 0.45V
                        PIN4 0.45V
                        PIN5 O.43V
                        PIN6 0V
                        PIN7 GND
                        PIN8...
                        11-20-2021, 08:32 AM
                      • acata
                        Lenovo Ideapad slim 3 not power on
                        by acata
                        Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
                        And the consumer asked for reinstalling OS.
                        I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
                        Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
                        Check the main power rail for 20v input ok
                        No amper input from Power supply 0.013a
                        Mosfet PQ201 20v and 26v ok.
                        3.3v exist
                        1,8v exist
                        5v exist
                        12v from baterai exist....
                        09-30-2024, 09:42 PM
