Acer Nitro 5 AN515-57-51G6, GH51GLA-L181P
  • nhe quan
    • Apr 2025
    • 27
    • Vietnam
    i will try and report but this relate to UVH2: VIN = 0V ?
    • mon2
      • Dec 2019
      • 14317
      US12 is a USB load switch & battery charger for the local USB port. Being shorted, other symptoms can follow. Flux and remove it and test again. At the very least, US12 must be removed and/or replaced.
      • nhe quan
        • Apr 2025
        • 27
        • Vietnam
        hello
        i break the IC =))
        but remove that and check Pin12 still short
        • mon2
          • Dec 2019
          • 14317
          i break the IC =))
          Would you not have flux and hot air tools to remove the part? If not, suggest to work with a local cellphone repair shop to service this laptop.
          Flux and remove CS5 capacitor. Then test the resistance to ground again. Is the short gone?
          If not, flux and remove CS6? Test again. The last part on this rail is the ESD TVS diode array @ DS2 (check if this part is on board). If not, the fault of the short is either CS5 or CS6.
          • nhe quan
            • Apr 2025
            • 27
            • Vietnam
            haha, i have them too, but my skill not good at all.
            already check by remove CS5 and CS6 still short so that DS2 are crash
            • nhe quan
              • Apr 2025
              • 27
              • Vietnam
              #26
              Break 1ic and loss cs6 🤣🤣🤣
              but i can order from aliexpress
              • mon2
                • Dec 2019
                • 14317
                Suggest to purchase flux + tweezers and practice on a donor board. Yes, Aliexpress will offer the replacement parts.
                Is the short condition now gone?
                • nhe quan
                  • Apr 2025
                  • 27
                  • Vietnam
                  #28
                  No so ds2 maybe a reason
                  • nhe quan
                    • Apr 2025
                    • 27
                    • Vietnam
                    #29
                    i remove DS2 => the short is gone
                    • nhe quan
                      • Apr 2025
                      • 27
                      • Vietnam
                      #30
                      mon2 i already replace DS2, the short is gone but still not power up,
                      and i check UVH2 VIN = 3V when press power button
                      • nhe quan
                        • Apr 2025
                        • 27
                        • Vietnam
                        #31
                        mon2 thanks for helping me alot,
                        i think replace the DS2 make my laptop alive but my mistake is not pateint for waiting boot sequence and using for measure trasistance when plug power.
                        so that +3VALW was shorted and PCH blew up. =(
                        • mon2
                          • Dec 2019
                          • 14317
                          Oh
                          • nhe quan
                            • Apr 2025
                            • 27
                            • Vietnam
                            #33
                            PCH blew up so that cpu and gpu my be take a damage right ?
                            • mon2
                              • Dec 2019
                              • 14317
                              Yes, PCH & CPU are in a single package. GPU may be ok but if the resistance to ground is low on the Vcore / same 3v3 rail you are measuring then the CPU is most likely damaged.
                              If you wish, inject 1 volt onto this rail and remove the heatsink on the CPU. Review which part heats up during this voltage injection. If it is the PCH / CPU, then the part is defective. Post the exact measurement you have on this +3VALW rail before starting. The same rail can be used to power the VIO pins on the PCH.
                              • nhe quan
                                • Apr 2025
                                • 27
                                • Vietnam
                                #35
                                thanks you very much but when i make short of +3VALW so that i think it the end of life kkkkk
                                i remove PU1901 but when i plug battery, plug charger and press power button so it make PCH blew up
                                replace PCH maybe so hard for me so well maybe i will sell it
                                Click image for larger version  Name:	image.png Views:	0 Size:	132.9 KB ID:	3627235
