MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
  • TechSplendid
    • Oct 2023
    • 14
    • Gelderland
    Hi All,
    I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
    Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior didn't change at all.
    I measured all the pins on JF600 in diode mode and compared them to values on OpenBoardData – everything seems to match.
    I still suspect the CD3217, but since these chips are hard to source and verify, I'm wondering if anyone has seen similar symptoms or knows if this could be caused by something else?
    Any input is appreciated!​
  • mon2
    • Dec 2019
    • 14198
    Test the LDO rails of each and every CD3217.
    • TechSplendid
      • Oct 2023
      • 14
      • Gelderland
      I'm not at home right now, but I'll measure that again later. What I did notice was: when I connect the charger to the JF600, I measure 0V on PPDCIN_AON. However, when I connect the same charger to a different port, I get 5V on PPDCIN_AON. That's why I still suspect the issue lies with the CD3217
      • mon2
        • Dec 2019
        • 14198
        Review the components linked to JF600. Be sure the USB C connector is not coated with cat urine or similar. Have seen some nasty connectors in our place that needed to be dunked inside of an IPA bath to be born again.
        Review the resistance to ground of the PPVBUS_USBC0 line used by JF600. Perhaps the TVS @ DF622 or DZF620 has triggered from a past transient event.
        • TechSplendid
          • Oct 2023
          • 14
          • Gelderland
          Thanks for thinking along, everyone. The connector (JF600) is fine, and all diode readings match the data in FlexBoardView. PPVBUS_USBC0 also measures correctly. DF622 and DZF620 also showed good diode readings.
          I just measured PP3V3_UPC0_LDO, PP3V3_UPC1_LDO, PP3V3_UPC2_LDO, and PP3V3_UPC3_LDO again. What stands out is this: when I plug the charger into JF600, I only get 3.4V on the suspected CD3217, and 0V on the other CD3217s.
          However, when I connect the charger to a different port, all CD3217s read 3.3V, with 3.4V on the CD3217 that belongs to that port.
          So as far as I can tell, the issue really seems to be in the area around the CD3217 and JF600. I'm just not experienced enough to fully understand why I'm seeing this behavior.
          Edit:
          It just occurred to me that the ROM (UF260) might be the issue. Unfortunately, I don’t have a donor board to test this. What do you think — could these symptoms be related to the ROM?
          • mon2
            • Dec 2019
            • 14198
            I believe the dump for that ROM is posted inside of the BIOS forum.
            • TechSplendid
              • Oct 2023
              • 14
              • Gelderland
              Yep, found it already. Thanks! Gonna try it out tomorrow.
              • TechSplendid
                • Oct 2023
                • 14
                • Gelderland
                Swapped the ROM chip, but no change unfortunately. Anyone have any ideas?
                • TechSplendid
                  • Oct 2023
                  • 14
                  • Gelderland
                  I've done some more measurements. I hope I've presented them clearly this way. It's a bit of a maze for me since I'm not fully familiar with the workings of the CD3217 yet, but maybe someone with these details can shed some light on what might be going on. What stands out to me is that the CD3217 (UF400) doesn't provide USBC0_3V3LDO_EN and UPC01_5V_EN​, regardless of which port I connect the charger to.
                  Charger on JF600 Measured on UF400
                  PPVBUS_USBC0 = 5.2v
                  PP3V3_S2 = 0.02v
                  PP1V2_S2 = 0v
                  PP3V3_UPC0_LDO = 3.456v
                  PP1V8_S2 = 0v
                  USBC0_3V3LDO_EN = 0v
                  UPC01_5V_EN = 0v
                  PPHV_INT0_AONSW = 0v
                  PP5V_S2SW_USBC01 = 0v
                  Charger on JF601 Measured on UF400
                  PPVBUS_USBC0 = 0v
                  PP3V3_S2 = 3.3v
                  PP1V2_S2 = 1.2v
                  PP3V3_UPC0_LDO = 3.3v
                  PP1V8_S2 = 1.8v
                  UPC01_5V_EN = 0v
                  PPHV_INT0_AONSW = 5.1v
                  Charger on JF601 Measured on UF500
                  PPVBUS_USBC1 = 5.2v
                  PP3V3_S2 = 3.3v
                  PP1V2_S2 = 1.2v
                  PP3V3_UPC1_LDO = 3.4v
                  PP1V8_S2 = 1.8v
                  USBC1_3V3LDO_EN = 1.8v
                  UPC01_5V_EN = 0v
                  PPHV_INT1_AONSW = 5.1v
                  • mon2
                    • Dec 2019
                    • 14198
                    Be sure the batteries in your multimeter are fresh. The following rails appear to be too high to me.
                    • TechSplendid
                      • Oct 2023
                      • 14
                      • Gelderland
                      Yes, I noticed that too. However, the 3.4V is only present on the CD3217 that's connected to the port where I have the charger plugged in. On the other CD3217s, I do measure 3.3V. So I don't think that's the issue, unless all the CD chips are faulty. What I'm more wondering about is why I don't have USBC0_3V3LDO_EN on that one CD3217. Could this mean the replacement CD3217 isn't working properly after all, or could it be something else?
                      • Adogabriel100
                        where to get trusted CD3217. Problem with A2337 Macbook Air
                        by Adogabriel100
                        Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                        The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                        09-06-2024, 12:06 PM
                      • LozinMust
                        Macbook pro 14'' A2442
                        by LozinMust
                        Hello guys,
                        I have an A2442 (820-02098) logic board with no visible liquid damage that had both CD3217B12 and ELC180 chips blown. After removing them, there were no shorts on the board but I still wasn't getting 20V in, so I suppose all the CD3217 are necessary to negociate 20V. As far as I can tell, the NAND chips are not shorted (I measured all the caps around them and didn't find a short), so I think that just replacing both chips should be enough to bring it back to life. Unfortunately, I don't have a spare board, but I can find CD3217 chips taken from A2442 boards on Aliexpress...
                        09-12-2023, 07:44 AM
                      • macabook
                        A2442 TOUCHID NOT WORKING
                        by macabook
                        I have an issue with a Mac A2442 , that had initially a short circuit on Q5800 after replacement it turn on without any other issue, only finger print not working. I follower the post " MacBook Pro M1 2021 A2442 Touch ID stopped working" by measuring in diode mode all SPI seems ok, but when checking for voltage i notice something strange regarding PP1V2_S2.
                        The chips UT620, UT520, UT540 are powered by PP1V2_S2 (according schematic and board view), this voltage is missing, and when I check continuity with PP1V2_S2 rail, found that it is not connected to it. Compared on another...
                        04-13-2025, 10:28 AM
                      • Noodneek
                        Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                        by Noodneek
                        My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                        I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                        08-30-2024, 12:52 PM
                      • Enzo150i
                        MacBook A2442 exclamation mark after oxydation
                        by Enzo150i
                        I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
                        The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
                        Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
                        We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to....
                        06-29-2025, 01:26 PM
