ACER ASPIRE 5517 burnt MOSFET
  • nearxos
    • Jun 2014
    • 41
    • Cyprus
    Hello.
    I got a faulty Acer Aspire 5517. took it apart and found a burnt mostfet (PQ35).
    through the schematics i found online i order some new mosfet a replace it.
    i re assemble the laptop to test it. and when i pressed the power button the laptop work for a few second (fan and power led turned on)and then stop.
    Took the laptop apart and checked the mosfet with a DMM and Drain and Source was shorted.
    i replaced the mosfet once again cause i though i didnt solder it well. but the same thing happened.
    above the mosfet i replace there is another mosfet(PQ36). Now the Source of PQ35 is Connected to the Drain of PQ36 acording to the schematics.
    Checking with the DMM i see that its connected to ground but according the the schematics its not.
    the schematic i have is this one. on page 42 you can see the relative circuit.
    https://www.badcaps.net/forum/showth...er+aspire+5517
    what else should i check around the mosfet? nothing else seems to be burnt.
    Not a native english so sorry for anything that doesnt making any sense in my writting.
    Thanks in advance
  • bushie
    • Dec 2013
    • 57
    • Romania
    Re: ACER ASPIRE 5517 burnt MOSFET
    change that integrated circuit PU12 : tps51117
    • pcbmaniac
      • May 2014
      • 81
      • Greece
      Greetings from Hellas.
      Before give dc power, do some measurements for low resistance to all inductors with earth. If you find normal resistances, give power and BEFORE press the power button, measure to all inductors looking for 3,3V and 5V as well. Do that and then we talk again.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3581
        • slovakia
        nearxos> check pq36 for short. if it is shorted, after the power button the vin is shorted through pq36 and high current blow pq35
        • nearxos
          • Jun 2014
          • 41
          • Cyprus
          Gia sou. kiprios eimai
          What will be a normal resistance messurement for the inductors. will it be in the range of ohms or Kilo ohms?
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3581
            • slovakia
            forget about it u have 3.3v and 5v good. 3.3 and 5v must be good to power on so u have it good.
            system detect short on switched powerrail and power off because didnt have PWRgood signal. in your case SUSGD or something like that.
            Focus on pq36 or short on that power rail.
            • nearxos
              • Jun 2014
              • 41
              • Cyprus
              I took out the pq36 and check it..it doesn't seems to be shorted. BTW what's the correct way to check if a MOSFET is shorted?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3581
                • slovakia
                if u took it out check for short on that rail
                but how do u know that pq35 is shorted when dont know how to check if it is shorted?
                look on youtube how to check it, because when u dont know , u can bad check and think it is shorted
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3581
                  • slovakia
                  i laptop is work for only few seconds check all power coils for woltage and if u find no woltage on some check on it for short.
                  i think u have amd northbridge so u can have shorted its rail
                  • nearxos
                    • Jun 2014
                    • 41
                    • Cyprus
                    no voltage on any of the power inductors in check
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3581
                      • slovakia
                      that means no start and u wrote this
                      "i re assemble the laptop to test it. and when i pressed the power button the laptop work for a few second (fan and power led turned on)and then stop."
                      so u must have some voltages on some powerrails.
                      • nearxos
                        • Jun 2014
                        • 41
                        • Cyprus
                        after the first attempt to replace PQ35 it did start for a sec.
                        Now it wont start at all.
                        i start check from the power jack.
                        on the power jack i got 19.5V
                        the on PL1 19.5 V
                        PQ7 on the drain i got 19.5V on the source i got 18.7 V
                        Next Pq8 is connected to PQ7 Source to Source. and on the Drain of PQ8 i dont get any voltage.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3581
                          • slovakia
                          its charging. dont bother it because your notebook not work
                          u have vin, so chceck 3.3VALW and 5V always
                          • nearxos
                            • Jun 2014
                            • 41
                            • Cyprus
                            Where should I check for 3.3v and 5v
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3581
                              • slovakia
                              search in schematic
                              • atsio
                                • Oct 2013
                                • 819
                                • Greece
                                Let's start from the beginning. Stop searching for the 3.3v and 5V.
                                Remove PQ35.
                                What is the resistance relative to ground on all pads of PQ35?
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3581
                                  • slovakia
                                  pq35 is really the beginning
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    Yes it is
                                    • nearxos
                                      • Jun 2014
                                      • 41
                                      • Cyprus
                                      Remove PQ35.
                                      Drain to ground resistance: started measuring 900 kΩ and gradually decreased to 110kΩ
                                      Source to ground resistance : 10Ω
                                      Gate to ground resistance 234 Ω
                                      i check for 3.3 V and 5V as advised earlier couldn't trace a 5V anywhere I did find a 3.3V on PQ13 but not on U41 according to the schematics
                                      • ktmmotocross
                                        Boardkiller
                                        • Feb 2014
                                        • 3581
                                        • slovakia
                                        chceck pl4 and pl5
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
