Asus X421ia chip ID
  • kalemaroni
    • Jun 2016
    • 189
    Asus X421ia chip ID
    Does anybody know what this chip is please?
  • mon2
    • Dec 2019
    • 14662
    Post a larger view of the same area. Attempting to view the same region in my BV file for this board. Especially the 6414 on the silkscreen - is this for U6414?
    • noname2024
      • Aug 2024
      • 293
      • CỎ MỸ XỊN
      USB CONTROLLER RTS5441S-GR//REALTEK QFN-32
      Click image for larger version  Name:	2025-02-27_084159.png Views:	0 Size:	97.2 KB ID:	3582155
      • kalemaroni
        • Jun 2016
        • 189
        Thanks very much
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • ebugs
          Asus laptop EC/SIO chip replacement
          by ebugs
          Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
          I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
          I found the EC chip...
          09-14-2024, 02:09 AM
        • pengamat_hebat
          Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
          by pengamat_hebat
          I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
          Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
          However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
          I also tried applying 3.3V to pin 3, but it still didn't work.
          I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
          03-25-2025, 04:13 AM
