lenovo G450 no back light on led screen.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    Re: lenovo G450 no back light on led screen.
    i got it guys... putting wire from pin 21 of u46 to pin 11 of JLVDS1 and got 3.3v to power light the led screen.
    thanks guys for all your help. god bless all.......
    • rickybucalan
      • May 2013
      • 322
      • philippines
      i got it and it works.... i put a wire on pin 21 of u46 to pin 11 of JLVDS to have a 3.3v to power up the led screen. thanks to all of you guys
      • rickybucalan
        • May 2013
        • 322
        • philippines
        hey guys its me again. i got same laptop here but this time it just a white screen
        i got no voltage on pin 2,4, and 6. that it should have 3.3v.
        here is my voltage reading.
        pin pin
        1. 20v 2. 0v
        3. 20v 4. 0v
        5. 0v 6. 0v
        7. 3.3v 8. 0v
        9. 0v 10. 3.3v
        11. 3.3v 12. 0v
        13. 3.1v 14. 0v
        15. 0v 16. 0.9v
        17. 0v 18. 1.2v
        19. 0v 20. 1.8v
        21. 0v 22. 0v
        23. 0v 24. 1.7v
        25. 0v 26. 0v
        27. 3.3v 28. 1.7v
        29. 3.3v 30. 0.5v
        • new
          • Oct 2014
          • 159
          • canada
          scrab it
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
            by sam_sam_sam
            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
            I am comparing them to a brand new one that I installed
            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
            I going to let it run for several days before I remount back on the wall next to the...
            09-05-2024, 06:48 PM
          • BlueNitesFire
            I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
            by BlueNitesFire
            So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
            03-08-2025, 03:49 PM
          • Noursa
            Lenovo Yoga C940-15IRH No primary Screen
            by Noursa
            Hello
            I'am a beginner in electronics repair and i got some trouble to find what's goning on a computer. It is a lenovo yoga C940-15IRH laptop and the screen doesn't work anymore, but that work on an external one
            the screen seams to be hard to unbuild properly so i want to test it by other way
            how can i be sure if the signal is really send to the screen ? i did some check on screen connector on LCD1 got 19v and on MiC1 connector on the other side of the screen (dunno if it's for the screen itself or other thing) got a lot of 3.2v pin
            did u got...
            05-04-2024, 10:00 AM
          • BMCappelletti
            Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
            by BMCappelletti
            Hi everyone.
            Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
            Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
            Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
            02-18-2025, 12:22 PM
