Alienware m15 r3 mb bap10 la-d751p rev 1.0 water damage repair request
  • koschmilla@icloud.com
    • Feb 2025
    • 6
    • Usa
    Hello. I spilled over night a marginal amount of water and this morning my Alienware m15 r3 didn’t turn on anymore. The charger was blinking when plugged in rather than showing a solid light when not being plugged in.
    opened her up and I see some liquid and discoloration. After a light cleaning, I can make out some damage around some power elements mainly a blown “4r7”. I tested with multimeter and would like to attempt to replace with some small components around.
    looking at my pictures, could anybody give me an idea how to proceed? The front of the board looks great.
    how much would a repair shop charge for replacing a couple elements? Tia
  • Sephir0th
    • Oct 2020
    • 1289
    As long as it isn't enough to replace the mentioned components to get the board working again, which is likely the case, you're not only oversimplifying the situation but also asking the wrong questions.
    This really likely needs proper troubleshooting and for me there is no fun to see while looking at the big exposed area. Looks really bad and was supposed to be cleaned right after the incident.
    Either way, first step is to clean the mess
    FairRepair on YouTube
      • Feb 2025
      • 6
      • Usa
      Would you think it’s worth giving it to a repair shop? I’d hate to throw it out since all other components were working before the incident. I checked all other dipole elements in the area and the 4r7 and two small ones to the top left are not showing continuity. I don’t know about the ics but all of them have continuity. Any advice is greatly appreciated.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        This is expensive machine-so strongly suggest to seek help from an experienced technician.
        Definitely its worth to give to a repair shop(check skills). Else,how people like us survive if everything is resolved in badcaps.
        • Ugur87
          MacBook Air M4 A3240 Brand New Water Damage no Image
          by Ugur87
          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
          08-28-2025, 01:09 PM
        • edugimeno
          Stagg sms12p audio amp has water damage
          by edugimeno
          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
          There is only one signal wire connecting the first boards...
          05-24-2025, 06:00 AM
        • Joel Ohana
          Lenovo IdeaPad 3 15IAU7 that suffered water damage
          by Joel Ohana
          I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
          Symptoms:
          • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
          • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
          What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
          03-06-2025, 11:25 AM
        • abajor
          A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
          by abajor
          Like title says A2141 came in with Water Damage, customer desperately wants the data.
          The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
          I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
          That said after cleaning up the...
          12-21-2024, 07:16 PM
        • s_henya
          Macbook Air A3114 5V 0.0A after water damage
          by s_henya
          Hi Mac experts :-)
          Im usually not getting too many Mac logic boards repairs, (mostly PC laptops)
          This Mac isn't powering on not boosting to 20v, stays at 5v with 0.0Amps.
          Took out the board and it suffered some water damage, see attached pics.
          All cleaned with IPA but due to long time with corrosion something already got shorted...
          any advice on the below:?
          1. Looking for relatively safe location for voltage injection as all of the caps around that area has 0.0ohms resistance.
          I tried injecting 0.5v on one of the caps...
          08-25-2025, 01:09 PM
