Asus X512DA - AMD Ryzen 5 3500U - No power
  • krayz
    • Nov 2021
    • 54
    • Slovenia
    Greetings
    I am trying to diagnose a laptop that wont turn on: no LED, no fan spin, no display, nothing. I dont know it's history apart from that it's been unused for a long time (a year maybe).
    The charger is good, as the laptop recieves the 19v at the power plug ( the 19v stops at the first MOSFET).
    Powering the board through the lab. PSU, it draws 10mAh.
    Measuring voltages on the inductors I get ONLY 3,3V.
    You can find the resistance measurements on the picture supplied.
    Further help would be appreciated.
    Thanks!
  • mon2
    • Dec 2019
    • 14236
    See attached. Locate PU8901 = Texas Instruments battery charger IC.
    Carefully measure the voltage to ground of pin # 4 = ACDRV on this charger IC. What is the voltage with the power adapter attached?
    This voltage should be ~25v to enable the 2 x DCin N-channel type mosfets. When the gate pin of each of the DCin mosfets is ~25v, the voltage between source & drain pins on the respective mosfets will pass through onto the main power rail.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      First thing to do is to check resistance between
      S-G
      S-D
      G-D
      of the 2 dc in mosfets.
      Next thing to check is whether 19V rail is shorted or not.
      If these 2 steps fails, then move on to charger ic requirements.
      • krayz
        • Nov 2021
        • 54
        • Slovenia
        Pin 4 of the IC shows : 0,2 V. Takes some time to stabilise.
        Checked the two mosfets and they are fine. The 19 V is not shorted.
        • mon2
          • Dec 2019
          • 14236
          Can you share the topside markings of these 2 x DCin mosfets? Need to confirm if they are N-channel or P-channel types.
          • krayz
            • Nov 2021
            • 54
            • Slovenia
            Ah, forgot to check that.
            • krayz
              • Nov 2021
              • 54
              • Slovenia
              additional info: whole AC_BAT_SYS is 3.3v.
              • pc_okay
                • May 2022
                • 241
                • FRANCE
                What about gate voltage of two first mofset you may see 0,2v?
                What do you see before stabilisation?
                did you Check without battery? 😁
                Check With charger only battery Line on PRS8902.
                • krayz
                  • Nov 2021
                  • 54
                  • Slovenia
                  I tested with everything removed, just the board and plug.😄 The voltage on the gates of the first two mosfets fluctuate just like the drains, from 0 to max 0,2.
                  Voltage on the PRS8902 you suggested i check is : 1,6V (without battery). I also traced the 19V line to where it gets lost: PR8932 (pin 1 is 19V, pin 2 is 0,5V).
                  • pc_okay
                    • May 2022
                    • 241
                    • FRANCE
                    Cool good news, check resistance of PR8932 it's supposed to be 10ohm.
                    And if reistance is ok check resistance to ground on pin 2.
                    You are supposed to have 19V on pin 2, this pin is connected to your IC charge chip on pin 28 (VCC), without it, you get no power for your IC.
                    You're IC cannot start without power, and work to open mofset....
                    • krayz
                      • Nov 2021
                      • 54
                      • Slovenia
                      I'm assuming the resistor must be desoldered for checking right?
                      I'm also wondering where the hell is that 3,3v coming from
                      • pc_okay
                        • May 2022
                        • 241
                        • FRANCE
                        You can mesure it directly on the circuit first. You don’t need an accurate mesurement, because you may find a huge value. (To drop 19v coming directly from charger to ~0v you need Mohm or OL!)
                        Before replacing the résistor Check résistance to ground on pin2, résistance often blown for a reason, you may have a short after.
                        Report you value please.
                        And yes for now I dont know too where 3v come from.
                        Maybe someone can give us an idea.
                        • krayz
                          • Nov 2021
                          • 54
                          • Slovenia
                          Results are ... dodgy
                          Click image for larger version  Name:	zoom_x512.jpg Views:	0 Size:	634.8 KB ID:	3561212
                          I'll try to remove it and remeasure everything next.
                          • pc_okay
                            • May 2022
                            • 241
                            • FRANCE
                            Résults are logical, yes you need to replace it.
                            It will not work without 10ohm resistor.
                            You don’t have miscroscope?
                            • krayz
                              • Nov 2021
                              • 54
                              • Slovenia
                              Although the boardview says 10ohm, doesnt the 100 marking on the resistor mean 100ohm? or am i missing something? To add: i havent replaced anything or worked on the board .
                              I do have a microscope, replacing wont be a problem. just got to find a replacement resistor on another board.
                              Thanks for the help
                              • mon2
                                • Dec 2019
                                • 14236
                                100 SMD marking on a resistor actually means = 10 * 10(to the exponent 0) = 10 * 10^0 = 10 * 1 (anything to the exponent 0 = 1) = 10 ohms = 10R.
                                So, 101 SMD markings = 10 * 10^1 = 10 * 10 = 100 ohms = 100R.
                                • krayz
                                  • Nov 2021
                                  • 54
                                  • Slovenia
                                  So I have desoldered the resistor and found that it really is faulty (shows 1,6 kOhm).
                                  I measured the two pads :
                                  pad 1 : ~10,5 kOhm
                                  pad 2: ~280 ohm.
                                  I also managed to find an identical, working resistor on another board and it is now soldered.
                                  I'm guessing that this isn't the root cause? Resistor don't fail just like that?
                                  • krayz
                                    • Nov 2021
                                    • 54
                                    • Slovenia
                                    Connected it to adapter. The replacement resistor actually died too 😅 (went to something like 280ohm+). I have another identical one, but i'll wait for further advice now.
                                    • Sephir0th
                                      • Oct 2020
                                      • 1282
                                      This means, the charging controller kills this resistor continously. Only logical conclusion is that the charging controller is shorted which normally should have been noticed after a closer inspection of VCC and REGN. tl;dr Replace the charging controller
                                      FairRepair on YouTube
                                      • pc_okay
                                        • May 2022
                                        • 241
                                        • FRANCE
                                        Yes change your ic chip and try again. 😉
                                          ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                                          This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                          09-07-2024, 01:00 AM
                                          ASUS VivoBook X512DA-EJ1326T Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook X512DA-EJ1326T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X512DA-EJ1326T boardview and X512DA-EJ1326T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:30 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                          ASUS VivoBook X512DA-EJ1375T Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook X512DA-EJ1375T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X512DA-EJ1375T boardview and X512DA-EJ1375T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 06:50 PM
                                          ASUS VivoBook X512DA-EJ1375T-BE Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook X512DA-EJ1375T-BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X512DA-EJ1375T-BE boardview and X512DA-EJ1375T-BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
