Asus X512DA - AMD Ryzen 5 3500U - No power
  • krayz
    • Nov 2021
    • 54
    • Slovenia
    I've ordered a new BQ IC. I also measured the voltage to pin 28 with the BQ removed and I get the 19V. Still curious why I'm getting 3.3v on my 19v rail... But we'll see.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      10 Ohms resistor blown always leads to charging ic being shorted. Pad2 resistance to GND clearly indicated that charging ic is faulty.
      That's why i always suggest to replace the ic whenever any resistor on vin/vcc line is blown. It has blown 'coz excessive current was drawn.
      This applies to all pwm ic and charging ic alone.
      • krayz
        • Nov 2021
        • 54
        • Slovenia
        Hello again. I have replaced the BQ chip and now i have 19v passing the input mosfets😎
        However, when I replaced the IC, the laptop still wouldn't start. Then I started poking around the IC with the multimeter to check some values, and found a problem and solution combo ^^.
        If i measure the voltage of pin 5 - PC_CHG_ACOK_10 (measuring on test pad that's right next to it), while the laptop is plugged in, it magically boots and charges. If i remove the probes, the laptop stays on, but stops charging. If I dont do this, the laptop does not respond to the power button.
        Thanks for the help so far
        • pc_okay
          • May 2022
          • 243
          • FRANCE
          First thing to do is to check resistance between
          S-G
          S-D
          G-D
          of the 2 dc in mosfets.
          Next thing to check is whether 19V rail is shorted or not.
          If these 2 steps fails, then move on to charger ic requirements.
          Please Check résistance on mofset (without power)
          You can Check ACDET voltage.(With power)
          And tell us your ACOK value With power, dont you short two pins when you Check ACOK?
          Review your soldier on IC, QFN chip are a pain to soldier if you are not used to.
          • pc_okay
            • May 2022
            • 243
            • FRANCE
            S-G
            S-D
            G-D
            Please Check résistance on mofset (without power) like mcplslg123 earlier.
            • krayz
              • Nov 2021
              • 54
              • Slovenia
              #26
              It really was a pain to solder i have resoldered it (i'm confident it's good enough), yet the same things are happening.
              The two DC in mosfets let the 19v as soon as i plug in the charger, so they should be good (but ill measure when i get home). It's just that the laptop is still unresponsive.
              Then i measure ACOK - charging and power led come on and the laptop starts.
              ACDET with power - 2,6 V
              ACOK with power - 1,3 V
              Looking at the BQ datasheet, I'm guessing that by measuring it with my multimeter, i am pulling ACOK high ? (don't know what this means though).
              • pc_okay
                • May 2022
                • 243
                • FRANCE
                #27
                Ok you progress.
                ACDET is fine.
                ACOK is problématique, ACOK is an ON/OFF signal you should get 0v or 3V not 1V or 2V or anithing else.
                ACOK provide power to your SIO via 3VA (3V always) so without it, you can’t have a power on.
                Check résistance to ground on ACOK Line, and Check PQ8905A, it may « kill itself » to protect your SIO during the overvoltage when IC charge burnt.
                Sending ACOK to the ground.
                That’s weird your laptiop start when you take your mesurement.
                How do you mesure voltage on ACOK? where do you put red and black probes?
                • krayz
                  • Nov 2021
                  • 54
                  • Slovenia
                  #28
                  There really is something funky going on ACOK line, when measuring resistance, it goes from 0,7kohm and just keeps rising slowly to over 1kohm. It sure doesn't do either/or with 0v and 3v.
                  When I measure ACOK, i put black to GND and positive to the test pad shown on picture.
                  How do i check if PQ8905A for proper functioning? according to the boardview it's this: https://fscdn.rohm.com/en/products/d...em6k6t2r-e.pdf
                  • mon2
                    • 14659
                    Post the mosfet measurements as requested above. The adapter voltage appearing downstream can be from leaky and defective mosfets.
                    • krayz
                      • Nov 2021
                      • 54
                      • Slovenia
                      #30
                      With resistance mode and the mosfets desoldered:
                      1.PQ8901 - QM3056M6AC
                      source (pin 1,2,3) to drain (pin 5,6,7,8) - 0 Ohm / 0.L
                      gate (pin 4) to source (pin 1,2,3) - 0.L
                      gate (pin 4) to drain (pin 5,6,7,8) - 0.L
                      2.PQ8902 - P0903BEA
                      source (pin 1,2,3) to drain (pin 5,6,7,8) - 0 Ohm / 0.L (and 0,5 Mohm if i reverse the probes for some reason )
                      gate (pin 4) to drain (pin 5,6,7,8) - 0.L​
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        #31
                        Source to Drain resistance is 0 ohms or OL? i'm bit confused with your writing.
                        • krayz
                          • Nov 2021
                          • 54
                          • Slovenia
                          #32
                          0 ohm when mosfet is on, 0L when it is off.
                          I used this as a guide:
                          https://electronicsbeliever.com/how-...-is-defective/
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #33
                            Never measure resistance with power attached.
                            • pc_okay
                              • May 2022
                              • 243
                              • FRANCE
                              #34
                              To check mofset you just have without power to put your:
                              • red probe on gate, black on source, then check resistance (has to be >= KOHM or OL), then revert probs
                              • red probe on gate, black on drain, then check resistance (has to be >= KOHM or OL), then revert probs
                              • red probe on source, black on drain, then check resistance (has to be >= KOHM or OL), then revert probs
                              At what point on the motherboard did you found ACOK =1,3 V?
                              Check this mofset too: PQ8905A with pin 1,2 and 9.
                              • krayz
                                • Nov 2021
                                • 54
                                • Slovenia
                                #35
                                You misunderstood, i measured the mosfets off the board, desoldered. What i meant with on/off is the mosfet itself:
                                "However, you should take note that when you put the positive of the DMM to the gate and the negative to the source of an NMOS, the MOSFET will turn on. You might mistakenly judge that the MOSFET is defective when you measure drain-to source resistance since the DMM will read 0 ohm. So, to avoid this scenario, ensure to discharge the charge on the gate".
                                The measurements of the 2 mosfets are like you specified.
                                ACOK is between 1-1,5v the whole time, even when the laptop is already booted.
                                ​I'l check PQ8905A and all the components on that line next.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  #36
                                  I know these facts with NMOS. I just guesssed that may be measuring with adapter connected. lot of people does this mistake. Anyway,doesnt apply in your case.
                                  • krayz
                                    • Nov 2021
                                    • 54
                                    • Slovenia
                                    #37
                                    I've measured PQ8905A (N-MOSFET EM6K1GT2R EMT6) as well. Resistance mode, no power. With both probe polarity.
                                    red (1) & black (6) 250 kOhm
                                    red (2) & black (6) 0,5 MOhm
                                    red (1) & black (2) 0.L
                                    black (1) & red (6) 75 kOhm
                                    black (2) & red (6) 0.L
                                    black (1) & red (2) 45 kOhm
                                    • krayz
                                      • Nov 2021
                                      • 54
                                      • Slovenia
                                      #38
                                      As i was checking the components on the line, I discovered something else as well. It would seem I blew off a component when replacing the BQ: PR8912.
                                      I replaced it with a resistor with the value taken from the boardview (100k). Now the ACOK pin gets 6V. The laptop is not turning on though (with just the adapter plugged in). So... don't know if this is progress or regress
                                      • mon2
                                        • 14659
                                        Progress. Now the rest of the logic board is receiving the ok signal to power up. Keep testing.
                                        • krayz
                                          • Nov 2021
                                          • 54
                                          • Slovenia
                                          #40
                                          I searched further and found that i have 3VA, but i don't have 3VA_EC, i'm guessing that's why it isn't turning on. Can't find the cause though. Also, isn't 6V for ACOK too high?
                                            ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                            09-07-2024, 01:00 AM
                                            ASUS VivoBook X512DA-EJ1326T Notebook 15 Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook X512DA-EJ1326T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X512DA-EJ1326T boardview and X512DA-EJ1326T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 05:30 PM
                                            ASUS VivoBook X512DA-EJ1375T Notebook 15 Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook X512DA-EJ1375T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X512DA-EJ1375T boardview and X512DA-EJ1375T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 06:50 PM
                                            ASUS VivoBook X512DA-EJ1375T-BE Notebook 15 Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook X512DA-EJ1375T-BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X512DA-EJ1375T-BE boardview and X512DA-EJ1375T-BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            ASUS VivoBook X512DA-EJ1407T-BE Notebook 15 Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook X512DA-EJ1407T-BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X512DA-EJ1407T-BE boardview and X512DA-EJ1407T-BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
