Msi gs66 charging issue
  • shahnld
    • Nov 2019
    • 159
    • Netherlands
    Good Evening Masters..
    My msi gs66 has a weird issue. It had a shorted mosfet on vram rails and 1x current sense to gpu or vram was melted,. I replaced the mosfet and currenr sense resister and the laptop started to work,
    but When plugged in it says battery is 99% and as soon as i remove the charger the laptop shutsdown.. beside this issue laptop is fully functional.
    So i opened it and i checked voltage on battery +. Without charger in MV's, when i plug in the charger then voltage on battery+ connector goes to 19.75v and then starts to drop until MV's. This happens with and without the battery,.
    3.3v is present on clk, data at bat connector,. I replaced both input mosfets. Input mosfets has 9v and 8v on gates.. bq24780s is also replaced but same issue..
    voltage measurments on bq24780s are as follows, any help is much appreciated.
    Pin, voltage
    1, 20v 2, 20v
    3, 20v
    4, 26v this voltage is not present on input mosfet gates.)
    5, 3.3v
    6, 2.6v
    7, 0v
    8, 0v
    9, 0v
    10, 1.027v
    11, 12, 3.3v
    13, 0v
    14, mv
    15, 0v
    16, 3.3v
    17, 2.5v
    18, 2.5v
    19, 2.5v
    20, 2.4,v
    21, 1.6v
    22, 0v
    23, 0v
    24, 6.085v
    25, 5.76v
    26, 2.33v
    27, 2.24v
    28, 20v
    Kind Regards
  • mon2
    • Dec 2019
    • 13992
    Pin 4 = ACDRV and often, this pin will mate with the gate pin of the DCin mosfets through a 4k series resistor. Respectively, the gate pins should also have the same boosted ~25v to enable each mosfet.
    Remove all power. Meter in resistance mode. Measure the resistance from the gate pin of the first mosfet to the ACDRV pin. Is there ~4k resistance? Repeat for the 2nd DCin mosfet.
    Is there a schematic available for your logic board? Link it in the schematic forum for a review. Hunt for this expected 4k resistor.
    Perhaps this expected 4k resistor is no longer ~4k ohms in resistance or is missing off the board? Basing these assumptions off the reference design schematics.
    Click image for larger version  Name:	typical.png Views:	0 Size:	201.7 KB ID:	3557550
    • shahnld
      • Nov 2019
      • 159
      • Netherlands
      Thanks alot for your reply.. i will trace down this resister and replace it. Will report back once that is done.. Cheers
      • shahnld
        • Nov 2019
        • 159
        • Netherlands
        Hi.
        I have checked. Both acFet and BatFet has 2 resisters which has 9v and 8v on it connected to gates. And both gates are also not connected togather.. Idea's...?
        • mon2
          • Dec 2019
          • 13992
          Share the silk screen details of your logic board. From random internet searches, the logic board should bear a silk screen like 'MS-16V1' which is one of many permutations used by MSI for the G66. Another is MS-16V31, etc.
          • shahnld
            • Nov 2019
            • 159
            • Netherlands
            Good Evening..
            I just replaced the battery from another msi laptop, batteries were identical in measurements, wire count and wire color location so i just installed it and to my surperise it worked in it. Its charging now and laptop works without charger. So conclusion is that the battery was dry dead due to not being charged for 7 months..
            Appreciate all the help and time.. 👍👍⚘️
            • Cuboy
              HP probook 4510s mosfet issue
              by Cuboy
              I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
              I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
              I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
              03-16-2024, 10:29 AM
            • ebyte64
              Lenovo IdeaPad 330 laptop mosfet issue
              by ebyte64
              Good day everyone.
              I have been scratching my head with a Lenovo laptop I got in today.
              The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
              Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
              Would anyone...
              06-27-2023, 10:19 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
              MSI Gaming Stealth GS66 12UGS-202UK Notebook GS Specification for Upgrade or Repair
              This specification for the MSI Gaming Stealth GS66 12UGS-202UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Stealth GS66 12UGS-202UK boardview and Stealth GS66 12UGS-202UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-07-2024, 07:12 AM
              MSI Gaming Stealth GS66 12UGS-259NL Notebook GS Specification for Upgrade or Repair
              This specification for the MSI Gaming Stealth GS66 12UGS-259NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Stealth GS66 12UGS-259NL boardview and Stealth GS66 12UGS-259NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
