Asus FA507 not charging the battery on main supply, only charing on USB-C.
This topic has been answered.
  • FrozenHaxor
    • Jun 2015
    • 266
    • Poland
    Hello, I have DA0NJSMBAD0 board that has dual charge ICs, one of them is BQ24800 and the other is ISL8238CH
    Now this is a very peculiar design, they're using the BQ to charge from the main 240W power brick path, and the ISL to charge from USB-C PD port.
    The ISL side works fine, but the BQ side does not. Battery is good.
    I have swapped it for BQ4780S as it's essentially an older version of the chip and there was no change. I get 19V VCC to the BQ, and the ACOK is 3.15V
    Any insights into what this could be?
  • Answer selected by FrozenHaxor at 01-24-2025, 03:15 AM.
    mon2
    • 14996
    ACN = 18.7V
    ACP = 19.5V
    This does not look right. There is a close to 0 ohm resistor across the ACP & ACN pins that is used for the current sensing. Respectively, the voltage on each pin should be very close. Double-check this measurement again.​
    • mon2
      • 14996
      There our countless cases of the same on this forum based on the BQ / Texas Instrument charger IC.
      Download a datasheet for this part.
      Check the voltage to ground of:
      ACDET
      REGN
      ACN / ACP
      ACDRV
      Post the list with their pin function name for a review. As noted in the above sticky by piernov - study the DCin mosfets that precede the ACN / ACP pins. If ACDRV is not ~25v then one of these mosfets is most likely defective.
      • FrozenHaxor
        • Jun 2015
        • 266
        • Poland
        ACDET
        REGN
        ACN / ACP
        ACDRV
        ACDET = 2.6V
        REGN = 6V
        ACN = 18.7V
        ACP = 19.5V
        ACDRV = 25.4V
        The laptop works and powers on, just isn't charging on this BQ IC, charges fine on the ISL when plugged to USB-C though.
        • mon2
          • 14996
          ACN = 18.7V
          ACP = 19.5V
          • FrozenHaxor
            • Jun 2015
            • 266
            • Poland
            Good insight, I only traced one current resistor to the ISL but didn't do it with the BQ as there are two of them, turns out there is internal trace broken to one sense pin, ran a wire and the readings are normal, charging came back.
            Thank you for the help.
            • semiRocket
              Toshiba 37bv701b power supply main rails
              by semiRocket
              The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
              I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
              Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
              10-26-2025, 01:55 AM
              03-31-2024, 02:12 PM
            • alltvrepairs
              Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
              by alltvrepairs
              I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
              I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
              Any one met this problem in the past?...
              10-08-2025, 07:34 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
              This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
              09-07-2024, 02:50 AM
