hp pavilion x360 Convertible 14-dy104np not powering up
  • Kambi13
    • Aug 2022
    • 134
    • Portugal
    Hi all need some help with this hp pavilion x360 convertible, board SLINKY 1.0 UMA, wont power up, no white led, nothing. I'm geting 19V up to the current sense resistor, but nothing from that point onwards. Doesn't seem to be shorted anywere, measured resistance in all inductors and they all seem good.
    Charger IC is ISL9538C
    Found no Schematics or Board View for this model
    Any help would be appreciated
  • FriedFred
    • May 2024
    • 137
    I know this IC. Can you measure the main power rail at any big capacitor?
    • pc_okay
      • May 2022
      • 241
      • FRANCE
      CARREFULY Check the voltage on the battery sense resistor WITHOUT battery, but WITH adapter connected.
      You may find battery voltage approx…
      If you find around 0V, CARREFULY check pins of ic with adapter and report it here.
      • Kambi13
        • Aug 2022
        • 134
        • Portugal
        I'm getting around 20mv
        • Kambi13
          • Aug 2022
          • 134
          • Portugal
          Can't get nothing past that mosfet
          • Kambi13
            • Aug 2022
            • 134
            • Portugal
            Main power Rail has 19.5V up to the current sense resistor shown in photo
            • pc_okay
              • May 2022
              • 241
              • FRANCE
              Yes don't worry that's normal you have à buck boost converter, so you will have only pulses at the gate and drain or the first mofset.
              You will not find the right voltage without an oscilloscope.
              But the circuit doesn’t seem to work, because you have almost 0V at the end.
              You can try first check the four mofset around the coil: Check résistance : (without adapter & battery)
              GÂTE TO SOURCE
              SOURCE TO GATE
              GATE TO DRAIN
              DRAIN TO GATE
              SOURCE TO DRAIN
              DRAIN TO SOURCE
              You have to find value > kOhm… or OL
              If everything si right you have to check the charging IC first check pins (CARREFULY, with charger, don’t short two pins with your électrodes!):
              PIN 16 (ADP)
              PIN 17 (DC IN)
              PIN 18 (VDDP)
              PIN 24 (ACOK)
              And report your values please.
              • Clarify4082
                • Oct 2022
                • 63
                Hi, I´ve the same issue with this board. 19V, no shorts.
                On Charging IC I have:
                PIN 16 (ADP) = 20V
                PIN 17 (DC IN) = 5.12V
                PIN 18 (VDDP) = 5.14V
                PIN 24 (ACOK) = 0.5 mV​
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  DC-IN should be close to 19V. You can refer to LA-F411 schematic for charging IC.
                  • pc_okay
                    • May 2022
                    • 241
                    • FRANCE
                    Please find a pretty similar schematic/boardview, just uploaded:
                    https://www.badcaps.net/forum/troubl...-slinky-203032
                    And yes you have a problem on IC powering.
                    You may check diodes on DC-IN line.
                    • check voltage before and after diodes
                    • check diodes in diode mode both side with multimeter without power
                    • Check for short before and after diodes
