Samsung S21 FE wifi not working
  • giulio93
    • Aug 2021
    • 284
    • Italy
    Hi everyone, I have a Samsung S21 FE with no wifi. I can't see the classic antenna cable so i suppose it is integrated in the circuit of the mobo. Can anyone help me with this?
    I have very good skills in soldering and stuffs.
  • giulio93
    • Aug 2021
    • 284
    • Italy
    No one can help me?
    • mon2
      • Dec 2019
      • 14753
      What is the history? Are you sure the fault is hardware related?
      https://eu.community.samsung.com/t5/...g/td-p/8986840
      • giulio93
        • Aug 2021
        • 284
        • Italy
        I tried to hard reset but the problem Is still here, so I suppose it's and hardware problem.
        So the problem could be the flat cable (te he G990U_FRC_R02?) or the commectors of It in the 2 board?
        Both the flat' connectors and the mobo's connectors seam fine to me
        • mon2
          • Dec 2019
          • 14753
          Post clear pics of the flex cable.
          • giulio93
            • Aug 2021
            • 284
            • Italy
            My phone don't have nice macro. I Will try, let me know of i have to focus on a particular detail
            • giulio93
              • Aug 2021
              • 284
              • Italy
              Do you see something wrong?
              • mon2
                • Dec 2019
                • 14753
                Did not see this till now. Mostly look ok but do review the attached.
                • giulio93
                  • Aug 2021
                  • 284
                  • Italy
                  Click image for larger version  Name:	review.png Views:	0 Size:	1.51 MB ID:	3545690
                  the connector is soldly down in plase.
                  In the "missing spot" i see 2 micro smd.
                  I don't understand the "switch". It is a question?
                  • mon2
                    • Dec 2019
                    • 14753
                    Is that a switch or a broken part of some type? Unable to see it clearly. Perhaps not related to the wifi fault.
                    Here is a good video on this model:
                    https://www.youtube.com/watch?v=T5qQjtJrxzc
                    The wifi cable should look like this:
                    https://www.aliexpress.com/item/1005004556516691.html
                    Was this unit water damaged? It is possible that the BGA balls are corroded if there was liquid damage to the phone and the WIFI module is not visible to the logic board.
                    • giulio93
                      • Aug 2021
                      • 284
                      • Italy
                      The wifi cable looks fine to me. The phone has no liquid damage. Do you know where the wifi chip is located? If it is a BGA, like I think, must be visible on the board
                      • mon2
                        • Dec 2019
                        • 14753
                        Review the post from amylen97 on page 1:
                        https://eu.community.samsung.com/t5/...s/td-p/9010242
                        • giulio93
                          • Aug 2021
                          • 284
                          • Italy
                          I've tried anything wrote in the link but doesn't work. I think is a hardware issue. I still did not understand where the wi-fi chip is. I woul try a reflow in the case
                          • mon2
                            • Dec 2019
                            • 14753
                            Hunt for an IC that may look like the following:
                            https://www.aliexpress.com/item/1005004304800748.html
                            • giulio93
                              • Aug 2021
                              • 284
                              • Italy
                              Yesterday I reflow the gray chip and the wifi come back to life!
                              Thank you all for your support
                              • mon2
                                • Dec 2019
                                • 14753
                                Well done! Apparently a very common problem with this model.
                                • Michal Timko
                                  Getac S410 G4 - not working second Wifi NIC.
                                  by Michal Timko
                                  Hello, first of all - thank you in advance for help.
                                  I got an Getac S410 G4 notebook with Intel(R) Wi-Fi 6 AX201 160MHz. Everything works fine, but we need to have another Wifi NIC because of VW/Audi Cars diagnostic software.
                                  So we added this one Realtek RTL8822CE Wireless LAN 802.11ac PCI-E Network Adapter to a free slot PCI-E 3.0 x1 port.
                                  NIC is installed correctly, basically it works, but we dont know how to enable the Wifi on it. It seems like it is still in Airplane mode - we are unable to turn of Wifi on this card. BUT - this card will turn on Wifi itself, after some time,...
                                  01-29-2025, 05:29 PM
                                • DynaxSC
                                  ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                  by DynaxSC
                                  I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                  Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                  Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                  The behaviour is also really very strange, i.e.:
                                  • The disk shows always up in BIOS - so it is recognized, so far so good
                                  • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                  02-23-2025, 01:33 PM
                                • Daveleone
                                  RESOLVED: Samsung UN46ES7100 WiFi not working
                                  by Daveleone
                                  I just wanted to post this here in case anyone else ran into the same problem.
                                  I had a UN46ES7100 and the wired Ethernet connection worked, but WiFi did not. Any time I tried to set up WiFi it would either 1) Show the available networks for a split second and then exit the menu, OR 2) Cycle forever looking for available networks and eventually go back to the menu. I know that these WIDT20R often fail, so I bought a replacement from China, but it exhibited the same problems. I did a little more research and found the following online:
                                  "Problems: Ue65es8000 - while doing wifi network
                                  03-10-2021, 11:20 AM
                                • Asraf Atb
                                  WiFi not searching, Blank Mac Address Samsung UE55MU8000 TV
                                  by Asraf Atb
                                  Hi guys thanks to forum I was able to fix my Samsung UE55MU8000 yesterday that was having a corrupted firmware, but now after it work i could not make work the wifi look like hardware is missing cause is not even searching just load bar but then not showing any wifi connections near to me, in the about page look like wifi Mac adress is blank do you have any suggestion?
                                  01-28-2025, 06:55 PM
                                • TrumanHW
                                  A1708 13 MacBook Pro Fn WiFi stops working | Turn OFF-ON WiFi = Temp Fix (1-6 min)
                                  by TrumanHW
                                  WiFi menubar symbol shows hardware stays connected (even when issue occurs)
                                  WiFi adapter shows normal connectivity symbol & stats: Using Opt+WiFi shows:
                                  • Tx Rate: 867 Mbps
                                  • RSSI: -44 dBm
                                  • Noise: -90 dBm (same as working MBP connected to same router)
                                  After ~1 min - 7 min, connectivity is lost (no traffic works) until I Disable / Enable WiFi (temporarily fixing again)
                                  Inspected Antenna connections (look secure) & UP / DL is quick when working (same as good laptop)
                                  • DL = ~400 Mbps
                                  • UL = ~17 Mbps...
                                  09-06-2022, 10:45 AM
