RESOLVED: Samsung UN46ES7100 WiFi not working
  • Daveleone
    • Apr 2016
    • 267
    I just wanted to post this here in case anyone else ran into the same problem.
    I had a UN46ES7100 and the wired Ethernet connection worked, but WiFi did not. Any time I tried to set up WiFi it would either 1) Show the available networks for a split second and then exit the menu, OR 2) Cycle forever looking for available networks and eventually go back to the menu. I know that these WIDT20R often fail, so I bought a replacement from China, but it exhibited the same problems. I did a little more research and found the following online:
    "Problems: Ue65es8000 - while doing wifi network search it would suddenly skip out or just close the menu completely .... no connect to wifi or nothing comes up while scanning for wifi
    in secret menu: sometimes i saw wifi MAC and sometime it show fail message
    solution :
    • turn tv off
    • with tv off press the following on the remote: info > menu > mute > power ( it is secret or service menu ) >>>> on my tv i had to press Mute>1>8>2>power to enter service mode
    • **be careful, don't change other things**
      • go to: Control > sub option and change "wifi region" and chose A
      • go back
      • go to: SVC > SVC reset
    • TV will power off. Power it on and your TV will ask you to config it"
    This actually WORKED for me and now everything is working perfectly. So, this appears to be a Samsung Firmware issue and not a hardware issue.
    Hope that helps someone!
    --Dave
  • Diah
    • Feb 2013
    • 6438
    Re: RESOLVED: Samsung UN46ES7100 WiFi not working
    i think with out changing region if you do hard reset (SVC > SVC reset ) any error at firmware will corrected.
      09-07-2024, 05:50 AM
    • Robby-Gr
      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
      by Robby-Gr
      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
      Additional issues:...
      09-27-2025, 12:02 AM
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Asraf Atb
      WiFi not searching, Blank Mac Address Samsung UE55MU8000 TV
      by Asraf Atb
      Hi guys thanks to forum I was able to fix my Samsung UE55MU8000 yesterday that was having a corrupted firmware, but now after it work i could not make work the wifi look like hardware is missing cause is not even searching just load bar but then not showing any wifi connections near to me, in the about page look like wifi Mac adress is blank do you have any suggestion?
      01-28-2025, 06:55 PM
      09-06-2024, 11:40 PM
