Lenovo IdeaPad 5 ITL05 | LA-K321P | Liquid Damage & No Charging
  • grimacelord
    • Jan 2017
    • 380
    I have an LA-K321P board here that came to me for no power. Upon visual inspection of the board, I found some liquid damage around PQB13 area. Replaced PQB1, PQB2, and PQB13. Laptop will power on if the battery has a charge, but the computer will not charge the battery. USB Type C meter shows 20V being negotiated, but virtually zero amp draw (0.0100 at most that appears for a brief second about once every 5 seconds or so). Looking through thermal camera, UT1 (SN2001024YBGR) is getting hot. I have schematic, but no board view. Was hoping someone could help me get this charging
    Link to schematic: https://www.badcaps.net/filedata/fetch?id=2100910
  • grimacelord
    • Jan 2017
    • 380
    Not really sure what to even check after I've replaced those few components that had visible liquid damage...
    • mon2
      • Dec 2019
      • 14685
      Can you post a pic of your board for this region? My BV looks different than yours.
      • grimacelord
        • Jan 2017
        • 380
        Hopefully the quality is sufficient. Thanks, mon2!
        • grimacelord
          • Jan 2017
          • 380
          Any ideas, mon2? I'm stumped.
          • Kridan
            • May 2024
            • Sverige
            I am having the same problem on a Ideapad, altso i notice one pair of cells voltage of about 6.4v at the charging port, so it actually backfeeds voltage from the battery out the charging port, otherwise same problem, charging voltage goes in, with battery in it starts and says its charging but its not, it's drawing a minuscule amount of power.
            Did you ever find a solution?
            • mon2
              • Dec 2019
              • 14685
              Missed the follow up on this thread.
              Remove all power. Meter in resistance mode. Measure the full path resistance of the battery charge circuit. Measure directly on the charger IC @ PUB1, pin # 19 & # 20.
              This full path resistance should be ~20 ohms. Confirm it.
              Click image for larger version  Name:	battery_current.png Views:	0 Size:	144.5 KB ID:	3586343
              • grimacelord
                • Jan 2017
                • 380
                Forgive me, but I am a bit confused on the instructions. I have found charger IC @ PUB1. Are you wanting me to measure the resistance between pin #19 and PRB19 and then pin #20 with PRB18?
                • mon2
                  • Dec 2019
                  • 14685
                  Correct. Sometimes / often, the resistance between these 2 pins is not matching the schematic values. Then the charger IC believes there is too much of a load in the charging process so the charging is halted.
                  • grimacelord
                    • Jan 2017
                    • 380
                    I'm getting 10.6 ohms on both.
                    • grimacelord
                      • Jan 2017
                      • 380
                      I may have measured wrong because I I was misunderstanding what you wanted me to measure. Resistance mode, one probe on pin 19, the other probe on pin 20, I am measuring 21 ohms. One probe on pin 19 and other probe on PRB19 is 10 ohms and same with the other. Hope that clarifies. Sorry for the confusion
                      • mon2
                        • Dec 2019
                        • 14685
                        Does this model offer a traditional barrel / coax power connector @ JDCIN1? Have you attempted to power the board using this method? Does it allow for charging?
                        The battery charger path resistance is within specification and is fine.
                        • grimacelord
                          • Jan 2017
                          • 380
                          Click image for larger version  Name:	adapter.png Views:	15 Size:	68.2 KB ID:	3587546
                          Sorry for the late reply. I became busy with other repairs.
                          No, this model does not have a coax/barrel charger. It uses USB Type C only.
                          EDIT: My mistake. There is a coax/barrel connector on the board it just didn't come with one installed and the hole in the side of the bottom panel isn't there to allow for a charger of this type to be connected. I would have to connect a DC-Jack and then drill the hole in the bottom panel if it worked....
                          • grimacelord
                            • Jan 2017
                            • 380
                            Wow. I just connected power through a USB-C meter to take some measurements and I saw a puff of smoke. Looked and see DT8 is now charred. Part CESD2510UC3V3U. Seems to be ESD protection. Coincidentally, this sounds very similar to another post I was following where you helped someone else with a similar problem, mon2. That post can be found here.
                            • av4x
                              Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
                              by av4x
                              Good morning, everyone!
                              I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
                              First up is a Fujitsu Lifebook U7511.
                              It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
                              Model: Fujitsu Lifebook U7511
                              CPU: Intel Core i5-1135G7
                              GPU: Intel Iris Xe Graphics
                              RAM: 16GB DDR4 - 3,200 MHz
                              PCB manufacturer: ASKPCB?
                              PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
                              Damage: Liquid damage
                              The liquid probably...
                              11-01-2025, 03:09 AM
                            • rounin
                              MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                              by rounin
                              Device Information
                              • Model: MacBook Pro 14” M1 Pro (A2442)
                              • Logic board number: 820-02443-05
                              Original Issue
                              The device suffered liquid damage, causing a short circuit on the logic board.
                              Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                              Work Performed
                              Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                              Current Status
                              • When powered on, the screen shows support.apple.com/mac/restore....
                              10-20-2025, 11:15 PM
                            • mon2
                              A1466 Macbook Air (Liquid damage repair)
                              by mon2
                              Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                              Macbook AIR Model A1466 Diagnostic 09-01-2021
                              Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                              Problems & Resolutions
                              1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                              09-01-2021, 09:31 AM
                            • rilley
                              MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                              by rilley
                              I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                              I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                              My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                              And the resistor L4004 is literally burned.
                              From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                              07-10-2024, 01:57 AM
                              Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 05:20 AM
