Macbook - silicone - screen pairing
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    I swapped screen on Macbook Pro M1 Pro (a2442) - swapped for original one from another one (original not aftermarket)
    there were shadows (i didn't swap ic's)
    after update to MacOS Sequoia 15.2 backlight is fully working no shadows.
    i tried restart, turn on off, close lid, ... it's working.
    can someone test if it's working for other people aswell ?
    also if possible test if aftermarket screens are also working???
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • MagJ_
    MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
    by MagJ_
    Hello Everybody,
    I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
    10-09-2024, 02:51 PM
  • sofles
    Macbook Pro 16" A2141 screen artefacts, kernel panic
    by sofles
    Hi there.
    I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
    I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
    Now situation looks like this, If...
    02-05-2025, 05:05 AM
  • ahoonid
    MacBook A1990 vertical stripes on external screen
    by ahoonid
    Hey everyone,
    I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
    The board is neat. Not opened before for sure. Just a little dust, nothing more.
    Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
    06-20-2025, 08:54 AM
