Thinkpad e15 FE4A0/FE5A0/ dead
  • Maurizio Merli
    • Dec 2024
    • 15
    • veneto
    Hi at all. My thinkpad is dead yesterday.
    After open the bottom board, i see PQ1101 go to burn after powerup.
    Probably is shorted? On the schematic is a n channel mosfet, marked as AONR32340C.
    Click image for larger version  Name:	20241221-144119.jpg Views:	0 Size:	1.86 MB ID:	3533451
    Hope someone help.
    Thanks,
    Maurizio
    • 20977
    PE606BA - https://www.badcaps.net/forum/troubl...86#post1672286
    • Maurizio Merli
      • Dec 2024
      • 15
      • veneto
      Thanks SMD. I replace it with this.
      Thanks again.
      Maurizio
      • Maurizio Merli
        • Dec 2024
        • 15
        • veneto
        SMDFlea can i buy safely on aliexpress?
        Thanks so much,
        Maurizio
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Replace both PQ1101/1102 along with pwm controller associated with these mosfets at one go.Else the new mosfet may get shorted again
          .After removing the controller ic plus both high/low side fets,measure resistance to GND on the coil to be sure its not shorted.
          • Maurizio Merli
            • Dec 2024
            • 15
            • veneto
            Thanks mcpl.
            The mosfet driver, is marked CG9. What did mean?
            I'm unable to find the datasheet.
            Thanks,
            Maurizio
            • mon2
              • Dec 2019
              • 14244
              See attached.
              Your board is NM-C421.
              Datasheet for this controller:
              ONSEMI # NCP81253MNTBG
              • Maurizio Merli
                • Dec 2024
                • 15
                • veneto
                Thanks so much mon2.
                Maurizio
                • Maurizio Merli
                  • Dec 2024
                  • 15
                  • veneto
                  Hi at all, i replaced all the mosfet and the driver, but before power-up i note, have missed (sadly with hot air) this little capacitor marked in orange.
                  What type of value have this capacitor? Before power up i wanna to install it.
                  Thanks,
                  Maurizio.​
                  • mon2
                    • Dec 2019
                    • 14244
                    Sorry, which capacitor?
                    The part in the square is PQ1101 = mosfet.
                    Is that part missing?
                    • Maurizio Merli
                      • Dec 2024
                      • 15
                      • veneto
                      Mon2, is the little cap immidiately on the left of PQ1101 and circle in orange. No the Mosfet is not missing.
                      • Maurizio Merli
                        • Dec 2024
                        • 15
                        • veneto
                        Sadly i don't find the pcb layout, it's on the net but i can't find.
                        Thanks,
                        Maurizio.
                        • mon2
                          • Dec 2019
                          • 14244
                          Probably mates with the nearby MOSFET. Use the meter in resistance mode to confirm which pins and share the details.
                          • Maurizio Merli
                            • Dec 2024
                            • 15
                            • veneto
                            Thanks mon2 i trace it with the schematic.
                            • Maurizio Merli
                              • Dec 2024
                              • 15
                              • veneto
                              Any continuity with the DC/DC converter with the mosfet.
                              I give up, without the component layout i'm lost.
                              Sorry again
                              Maurizio.
                              • Maurizio Merli
                                • Dec 2024
                                • 15
                                • veneto
                                Ok i find the component i lost, it's not a capacitor, is PT0008 (prf15bb541nb6rc) a NTC thermistor, 640 ohm made by murata.
                                I hope to find it a replacement.
                                • Maurizio Merli
                                  • Dec 2024
                                  • 15
                                  • veneto
                                  I find this murata ptc are 540 ohm not 640. But is impossible to find an equivalent.
                                  How substitute this?
                                  Thanks so much again,
                                  Maurizio.
