Searching compatible USB PORT PREDATOR PH16-71 DAZGRMB2AC0 REV 0
  • pc_okay
    • May 2022
    • 243
    • FRANCE
    Hello friends,
    I'm looking for a replacement USB port for an ACER Helios but I can't find the exact one...
    Do you know where i can find a compatible port?
    PREDATOR PH16-71
    DAZGRMB2AC0 REV 0
    On boardview i found this, but it doesnt seem to be relevant:
    CN2TA1
    10697-09101​
    Thank you. 😀
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    search aliexpress look for USB 3.0 A Type Female Socket Connector
    Never stop LEARNING because life never stops TEACHING!
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      make sure the orientation is correct before you buy. Good Luck
      • pc_okay
        • May 2022
        • 243
        • FRANCE
        Thank you but I can't find a perfect match or good match... 😥
        Little connector on the side of the connector never match.
        Please look a this photo.
        • mon2
          • Dec 2019
          • 14664
          These are called mid-mount USB connectors.
          How about connector # 507 from this vendor?
          https://www.aliexpress.com/item/3283...Cquery_from%3A
          Best to start a chat to request the dimensions to compare against yours.
          Unable to make out the through hole pins on your connectors for a comparison. Post more pics of your rearside pins on this female connector but the above may be a good candidate.
          • R_J
            • 9607
            How about this one? 3pcs USB Jack Socket Power Charging Connector for HP Pavilion G4 G7 G6-2000 G6-2100 G6-2200 G6-2300 USB 3.0 Port - AliExpress 13
            • mon2
              • Dec 2019
              • 14664
              Nice find R_J. Looks like a winner to me. OP needs to confirm the dimensions of the depth and if the staggered pins will align.
              • pc_okay
                • May 2022
                • 243
                • FRANCE
                Thank you all! i think that's a good match.
                I'll try this and i'll confirm you.
