Need help identifying components HP EliteBook 840 G3
  • Boyan
    • Nov 2024
    • 7
    • Bulgaria
    Hello Guys,
    Can you please help me identify these components from the motherboard. I saw a similar topic, but it was for HP840 G4 (https://www.badcaps.net/forum/troubl...arging-problem) Are those described there the same components?
    In the first picture, I have circled in red the burned components. It was due to short switching positive with negative. Probably the motherboard will not work, but I can try to repair it. It is a laptop for experiments, so no big deal if it cannot be repaired.
    Thank you
  • mon2
    • Dec 2019
    • 13830
    OMG. Good catch on the comparison of the 2 boards! Looks the same to me.
    Flux and remove the 3 legged TVS part you have circled. It is intended to clamp the peak voltage to 24v.
    • Boyan
      • Nov 2024
      • 7
      • Bulgaria
      What do you think about the second one which is completely burned? It is the top circle.
      Do you think is the same as here? https://www.badcaps.net/forum/troubl...-problem/page2
      First post on the page.
      In my opinion, HP EliteBook 840 G1, G2 and similar 820, 850 or same generation are pretty much the same. The next one HP EliteBook 840 G3, G4 or G5 can be very close in this part, as well. And all of them can have pretty much the same design in these parts, with slight differences depending on available parts. I doubt HP will bother with designing each motherboard differently, they will try to make as little changes to keep the cost down. Probably many other motherboards are with similar design and components.
      • mon2
        • Dec 2019
        • 13830
        Based on the other schematics, the missing part is probably an inductor. Confirm this by removing all power. Meter in lowest resistance mode. Short your meter probes to check the lowest resistance your meter can measure. For example, our Fluke will read as 0R3 ohms when the probes are shorted. Then place a meter probe on one side of the pcb pad that is missing this part. Next meter probe on other nearby parts to locate a part that mates with this missing component. Which part shows as '0R' ohms? We can use this information against the schematics we have to determine which part is actually missing.
        Likewise, repeat this process with the other side of this missing part - touch the PCB pad. Then hunt the PCB to locate which other part mates with this side of the missing part. Again to validate which part is missing using the example schematics we do have in our knowledgebase.
        • Boyan
          • Nov 2024
          • 7
          • Bulgaria
          I have attached updated image with the connections for the burned component that I found so far. I think this should be enough for now.
          • Bonzas
            • 466
            • Indonesia
            • Boyan
              • Nov 2024
              • 7
              • Bulgaria
              So, any idea what this component is?
              • Sam Scarbo
                Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
                by Sam Scarbo
                My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
                I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
                If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
                See the attached two pictures of the small...
                09-18-2024, 08:29 AM
                HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                09-07-2024, 05:50 AM
                HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                09-07-2024, 05:20 AM
