Re: HP EliteBook 840 G4 charging problem
See attached.
My paid schematic database does not reference your exact 840 G4 model but did find a 840 schematic.
This may be a challenge since we are not sure if my schematic matches your logic board but so far, the transient diode is a match.
This is a 24V part and like the users above, you should be OK to replace the part with the following:
https://www.direnc.net/pesd1can-ht-s...-transil-diyot
Let me post a few other references for you to check on your logic board. After this confirmation, we should be in a good position to understand how this board operates.
The damaged part is not the show stopper.
See the attached portions of the charger schematic.
Do you see a mosfet (8 legs; 4 on each side) with markings of "AON7403" ?
Post clear pics of the black mosfets on your board.
Also check to see if you can locate - should be nearby, a charger IC from TI. This charger IC most likely will be marked with "BQ736". Confirm if it is present on your logic board.
See attached.
