MacBook Pro M2 A2338 with PowerSupply it is running, "X" on the battery symbol and FAN is running permanently
This topic has been answered.
  • Schluchti45
    • Oct 2024
    • 6
    • Austria
    I have a MacBook Pro A2338 M2. The MacBook runs with the power supply unit. The fan runs permanently and the battery shows the message “Service recommended”.
    I have already replaced the battery with a new one, but this has not helped. I have also tried DFU and the system restored the error remains the same.
    Do any of you have any ideas where I could look or how I should proceed here?
  • Answer selected by Schluchti45 at 11-18-2024, 01:50 AM.
    reformatt
    • Feb 2020
    • 1537
    Have seen this with a damaged battery flex cable on a 2022 A2338 recently. Fan ran flat out and battery not communicating via SMBUS. The cable is identical to that used on the A1706 BTW.
    Couple of keys on that one also not working and I swapped out the palmrest as well......customer later tells me that he believes a rat pissed on it. Oh thanks for telling me AFTER I've fixed it.
    • mon2
      • 14740
      Measure the voltage to ground of each pin on the battery connector.
      • reformatt
        • Feb 2020
        • 1537
        • Schluchti45
          • Oct 2024
          • 6
          • Austria
          Thanks for your hints, i have ordered a new flex cable for the smbus and will check if this helps. i will also check the communication on sdl and sda. kind regards
          • Schluchti45
            • Oct 2024
            • 6
            • Austria
            my new flex cabel now arrives and i installed it. Now the MacBook is working without any problems. Thanks for your input.
            • Orux
              Macbook Pro M1 A2338 13"
              by Orux
              I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
              I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
              One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
              09-22-2025, 12:54 PM
            • sdogs
              macbook pro M1 a2338 no video on internal display PP3V3_S2 short
              by sdogs
              Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
              First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
              I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
              06-27-2025, 01:58 PM
            • sdogs
              by sdogs
              06-27-2025, 11:26 AM
            • classicandy
              MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
              by classicandy
              Hi Everyone,
              Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
              UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
              04-14-2024, 12:00 PM
            • User555111
              A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
              by User555111
              Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
              02-05-2024, 08:16 AM
