Dell XPS 13 9310 - Repair
  • Diego Eloren
    • Jan 2024
    • 7
    • Albania
    i have an DELL XPS 13 9310 to repair.
    It's mainly a Gen 11th I7 with 32GB of RAM.
    The error is that it flashes 2x amber and 4x white, which indicates a RAM Error according to dell.
    I had a dell logo and wasn't able to access BIOS menu.
    I measured the the surroundings of the RAM and used a thermal camera to see anything abnormal. I couldn't find an issue.
    So I decided to re-flash the BIOS, because it has no BIOS battery and the use case of the laptop, i wanted to eliminate a kind of corrupt BIOS.
    I desoldered the BIOS chip and made a few backups and made md5sum cross-comparision.
    I made a BIOS request here: https://www.badcaps.net/forum/troubl...30#post3482330
    hoaca388 kindly provided a BIOS Image. During the soldering, i killed accidently the chip, I removed it again and wanted to check its content, but the chip doesn't respond to ID checks.
    The BIOS Chip is/was a XMC25QH256B
    Click image for larger version  Name:	image.png Views:	0 Size:	331.9 KB ID:	3482765
    The problem is that these chips are hard to source. Is it possible to replace the chip with a Winbond W25Q256FVEx / W25Q256JV Type?
    I am happy with each comment.
    Thank you in advance.
    Best regards, Diego
  • capoplays
    Help with BIOS update on Dell G15 5515 after chip replacement
    by capoplays
    Hey everyone,
    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
    When I check the BIOS using the F12 menu Flash...
    10-24-2025, 06:53 AM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • ezenia
    Dell G3 3579 BIOS chip ID
    by ezenia
    I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
    06-16-2025, 08:07 PM
  • JoWed
    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
    by JoWed
    Hello Community,
    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
    07-01-2025, 09:32 AM
  • ed1i
    Dell Inspion 7610 bios chip
    by ed1i
    Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
    01-16-2025, 02:14 PM
