Hp Compaq CQ61 fast runs off
  • hercooles
    • Sep 2011
    • 7
    Hi!
    I already read some topic about CQ61 problems, but did not find any solution to my problem.
    CQ61-315SH
    Symptom: LED lights under DC, Battery charging = 2sec after turning on laptop turns off
    I tested with another Intel CPU, same.
    BIOS voltages looks OK for me, but can it be corrupted?
    leg1: 0.16V
    2. 1.65V
    3. 3.37V
    4. 0.0V
    5. 0.22V
    6. 1.54V
    7. 3.36V
    8. 3.37V
    Any ideas?
    Thanks you
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Hp Compaq CQ61 fast runs off
    check for short on switched power rails
    • helderfb
      • May 2014
      • 16
      • portugal
      Program Bios
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        BIOS voltage is not normal. Do/try the following:
        1. Do as helderfb said (Reprogram bios)
        2. Measure RSMRST# for 3.3v (if it is 3.3v during prior or after power button press)
        a. if the voltage is 3.3v there is possible problem with your secondary voltage regulator
        b. if no voltage is present reflow/replace SIO.
        3. Measure the resistance of the coil with respect to ground. Check the circuit where you measured less than 10 ohms.
        4. Report back your results.
        • hercooles
          • Sep 2011
          • 7
          Thank you guys, KBC + bios flash helped!
