Acer Aspire 5755(LA-6901P) No Display
    Model: Acer Aspire 5755 (i5 Intel Graphics)
    Motherboard: P5WE0 - LA-6901P
    Symptoms : Power on the laptop but nothing on the screen.Fan spins/DVD-RW spins/ Lights up/ Battery Charging But no HDD LED light up.No boot loops or shut downs.
    Other details:
    01. Northbridge has higher temperature no other chips are over heating.
    02. BIOS (Main + EC) Re- programmed.
    03. +3.3VALW and 3.3VS / +5VALW and +5VS available.
    04. PL20 = 1.17V, PL21= 1.15v, PL18=0V (+VGFX_COREP)
    05. Ground to PL18 multi-meter shows 010
    06. RAM and CPU Changed.
    Could you please someone tell me where should I start for a solution for this matter.Thanks
    Re: Acer Aspire 5755(LA-6901P) No Display
    Here are the pin volatges of PU12
    pin22 (VDD)=5v
    pin23 (VIN)=18.98v
    pin7 (VR_ON)=3.3v
    pin8 (PGOOD/VGATE)=3.3V
    pin2 (IMONG/GFXVR_IMON)= 0V
    pin3 (PGOODG/GFX_CORE_PWRGD)=0V
      hi, i have a 5750g with no display. only nb is getting hot. do you think that is the problem? did u solve your problem with the laptop ?
        did you try to reflow?
          nope... will try later
          edit tryed reflow both nb but no go, then vga, but no go ...
            client or your notebook?
            cook it!
              it was a client pc. tried both bios reprogramming and reflow on nb and gpu but still the same. i think ill go for nb reballing...
              OT
              today i had also an acer 5532 with no display. after a reflow on rs780 amd , it come back to live.
              end of OT
                Originally posted by kandyan View Post
                model: Acer aspire 5755 (i5 intel graphics)
                motherboard: P5we0 - la-6901p
                symptoms : Power on the laptop but nothing on the screen.fan spins/dvd-rw spins/ lights up/ battery charging but no hdd led light up.no boot loops or shut downs.
                Other details:
                02. Bios (main + ec) re- programmed.
                03. +3.3valw and 3.3vs / +5valw and +5vs available.
                04. Pl20 = 1.17v, pl21= 1.15v, pl18=0v (+vgfx_corep)
                05. Ground to pl18 multi-meter shows 010
                06. Ram and cpu changed.
                Could you please someone tell me where should i start for a solution for this matter.thanks
                please give me the bios file that main,ec .
