Charging macbook pro mid 2014 15" with magsafe 2 60W charger
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Hi guys.
    May I charge this model with 60 W charger?
    I know it requires 80 W to charge, but don't want to buy one.
    If it specifically requires and 60 W can damage macbook and vise versa, I guess I will have to buy 80 W one.
  • reformatt
    • Feb 2020
    • 1528
    It will run off it but not charge the battery. 60W is for A1502, A1398 needs 85W.
    • paparazzo79
      • Dec 2018
      • 303
      • Bosnia
      U sure it won't charge the battery?
      he used modified Toshiba 60 W charger and told me it charged it.
      • paparazzo79
        • Dec 2018
        • 303
        • Bosnia
        So I purchased the new charger but it is fake, got scammed.
        To be quite honest genuine are rare to find here.
        So I dunno should I use it, cuz I am scarred it will damage the laptop.
        • mon2
          • Dec 2019
          • 14693
          The fake chargers lack the soft-start mechanism that is present inside of the original power adapters. That is, they are 'hot' as soon as you plug in the AC power source to the power adapter if it is a fake. Respectively, if you scrape / touch the contacts onto a metal surface, there will be sparks. The original adapter is off till the logic board mating is confirmed and only then the higher voltage is enabled.
          A suggestion (only) is to consider a USB Type C to magsafe adapter. Then use a reliable USB Type C power adapter that has OVP / OVC protection. About to meet with a few thousand power adapter manufacturers in HK next week - will ask around if they have reliable solutions for magsafe adapters. Many do not even have proper certifications such as CE / CSA / UL approvals but are 'cheap' on price.
          • reformatt
            • Feb 2020
            • 1528
            USB-C to Magsafe 2 adaptors (from China at least), suffer the same issues as the knock off's as all the smarts are in the plug itself. I have a few I use with a 87W USB-C charger - they work but won't power on a board without battery. The knock off's cause BATLOW to remain low, and they only work in the presence of a working battery.
            Original Apple chargers are much more expensive (usually over $120 here in Australia). Knock offs are around $35 so that gives you an idea of the authenticity. Hackaday did a teardown of each some time ago, the knock off internal construction has many components missing to that of the original, such as a PFC at the head of the switch mode. Pretty sure the quality of the DC will be quite shitty too, but the internal power supply of the MAC can filter that out.
            The SMC determines what type of charger is connected by the one wire circuit, that info comes from within the magsafe plug itself. Unless 85W is connected (or one of those 100W PD USB-C to Magsafe chargers from China), then it will refuse to charge the battery on A1398.
            • mon2
              • Dec 2019
              • 14693
              Good info. Thanks. Locally we have Mobile Sentrix who offers grade A/B OEM power adapters. Just ordered one tonight at $30 Canadian + shipping for a 60W t-style MagSafe 2 for powering an A1502. Their presence is strong in the USA and Canada and kind of like a mini version of AliExpress. They are very receptive to feedback. They have started to carry at least 3 different items we requested. I am so close to ordering the u-bos2 tool which is required for an iMac 2017 but will try my luck at the Wanchai computer mall next week. Maybe someone will have an affordable T2 flash for a desperate Canadian.
              • paparazzo79
                • Dec 2018
                • 303
                • Bosnia
                Ahh my friend I can not find genuine charger, and more even complicated the magsafe adapter.
                Sorry I opened new thread.
                it is just that macbooks are not populary used here.
                And people mostly sell them without chargers.
                • paparazzo79
                  • Dec 2018
                  • 303
                  • Bosnia
                  I connected the 60 W genuine charger and it is charging battery normally.
                  But the output is 19V not 20V.
                  i suppose there is +/- 0.5 V tolerance, so is fine.
                  • spidertnt
                    • Jul 2016
                    • 34
                    Its the other way around ....it will charge slower but fine. it will not run / post if using low watt charger when battery disconnected. Always use a 85watt OEM charger on your test bench. 3rd party charger power ratings are meaning less
                    • dimis1975
                      Macbook A1466 2014 not charging with macsafe 2 charger
                      by dimis1975
                      I have a macboook air a1466 that stopped charging the battery.
                      BAT PINS: with or without ADAPTER IN
                      1- GND
                      2- GND
                      3- GND
                      4-0V sense pin
                      5-3.42V
                      6-3.42V
                      7- 8.4V
                      8- 8.4V
                      9- 8.4V
                      AC Adapter plugged in: after a lot of of hours some times start charging
                      No BAT Connected- Green to Orange
                      AC Adapter plugged in: BAT Connected- no light
                      The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
                      Any ideas what’s wrong please?...
                      08-05-2025, 03:43 AM
                    • echothegamer
                      Macbook A1466 dies when charger disconnected
                      by echothegamer
                      Hello all,
                      Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                      Details:
                      Macbook 13' A1466
                      Board (820-3209-A)
                      Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                      Pictures below of Boardview and schematic...
                      I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                      It's an older model and it is very likely that battery has become...
                      10-28-2023, 12:00 PM
                    • ritalo
                      MacBook Air 13 2014 - Remove EFI password
                      by ritalo
                      I have a MacBook Air 13 inches 2014.
                      I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                      I know how to remove the password with a usb programmer.
                      I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                      Then I have to find this value in the file : $SVS because it indicate where is the password.
                      But I can't find the value.
                      I have attached the file​
                      Thank...
                      05-14-2024, 12:10 PM
                    • envym
                      MacBook Pro 2018 with Activation Lock
                      by envym
                      Hi everyone!
                      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                      06-27-2025, 08:54 AM
                    • motormayhem
                      Lenovo T460 Only Charges on One Charger
                      by motormayhem
                      Laptop Question
                      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                      05-12-2023, 01:46 PM
