Lenovo NM-D562
  • hopkok
    • Oct 2014
    • 179
    • Slovakia
    Lenovo NM-D562
    Originally posted by mon2
    Hello.
    1) Remove all power. Meter in resistance mode. Measure the resistance to ground @ P3 label = main power rail to the logic board. What is the resistance in ohms? If the resistance is low = shorted part on the rail, then the DCin mosfets will remain OFF.
    2) To check the DCin mosfets @ PQ5401 / PQ5402 -> remove all power -> meter in resistance mode.
    Measure the resistance to ground of:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement. Check both DCin mosfets. Checking for a low resistance = defective mosfet.
    Hi Mon 2, I have got same problem, no voltage at point2. All input mosfets OK, no low resistance.
    Chager IC BQ24780s has VCC presented -20V.
    ACDET at pin 6 has 2,7V
    ACOK pin 5 - 0V
    I tried to replace charging IC, but the same.
    From charged battery, its working.
    Do you have any idea? Thank you
  • mon2
    • 14664
    Hi. Best to remove all power -> measure the resistance across each mosfet. Post each measurement for a review. A good mosfet should be hundreds of kohms or higher.
    What is the voltage to ground of ACDRV on the charger IC? A good working charger IC should be ~25 volts = adapter voltage + REGN (~6v) = 19v + 6v
    • hopkok
      • Oct 2014
      • 179
      • Slovakia
      ACDRV - 0V,
      PR5404 - OK
      PR5402 - OK
      REGN - 6V
      Let me double check mosfets tomorrow
      • mon2
        • 14664
        ACDRV is 0v so something is wrong. As per sticky above by piernov on charger ICs, the Dc-in mosfets are suspects. Need the exact resistance measurements. Likely at least one of these is defective.
        • hopkok
          • Oct 2014
          • 179
          • Slovakia
          Hi mon2, PQ5402 was faulty, resistance more than 20 kohms, checked in diode mode too, 0,5V drop, seemed to be OK, I tried to replace anyway and its working...thanks for hint
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
          • CornholioGSM
            Lenovo X1 Extreme G3 (LPM-3 MB 19770-1) (BQ24780S)Fake charging, working on battery. Help needed
            by CornholioGSM
            Please i need help from you how to check what is bad on this device.
            Laptop turns on normally on charger or on precharged battery, but is unable to charge - in system shows charging but not charging.
            Originally was blown dual mosfet near gpu.
            EDIT - after few mins on charger windows says 100% chaged with exclamation mark and something like "please check charger"
            Charger is new original 100Watt
            Motherboard LPM-3 MB 19770-1
            Charging is BQ24780s
            Schematics here : https://www.badcaps.net/filedata/f...
            07-06-2025, 01:22 PM
            Lenovo 3000 Series Schematic
            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
            3000 C100 laptop with Braille keyboard
            Lenovo 3000 C
            C100, C200 - 15-inch XGA screen
            Lenovo 3000 N
            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
            N500 - 15.4 inch screen.
            Lenovo 3000 V
            V100, V200 - 12.1-inch WXGA models
            Lenovo 3000 G
            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
            10-04-2024, 06:05 AM
            Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
            This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
            09-06-2024, 06:40 AM
            This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
            09-06-2024, 06:06 AM
