ASUS Battery B31N1726 diagnosis
  • PowerAmpFreak
    • 982
    • Sweden
    I had a ceramic cap failure in an ASUS G731 across the main system rail, and after replacing the cap, laptop works good. The only thing which is not OK, is there are no voltage on the battery-line.
    So my question is: Can a direct short across the main system rail kill the battery?
    Can I try to charge the battery with a current limited lab supply to diagnose the battery?
    See the attached picture. The obvious black and red wires, but there are one white and one yellow aswell. Do I have to "enable" the battery terminals in any way through shorting any to minus or similair?
    EDIT: I now could see in the service manual that the yellow and white wires are CLK and DATA for the BMS.
  • PowerAmpFreak
    • 982
    • Sweden
    Is it common for a battery to fail when exposed to a shorted system rail?
    The battery outputs zero volts after this. Is there a built in fuse in the battery that can be replaced?
    • mon2
      • Dec 2019
      • 14659
      Disconnect the battery. Meter in dc voltage mode.
      Power on the logic board using only the power adapter.
      Carefully measure the voltage to ground of each contact of battery connector on the logic board. Post each measurement.
      Mostly interested in the voltage measurements of the scl and sda pins on the logic board.
      • PowerAmpFreak
        • 982
        • Sweden
        + pole on battery 0.2V
        SCL and SDA has data (checked with a scope)
        • mon2
          • Dec 2019
          • 14659
          So the SMBUS lines on the logic board are not shunted due to an ESD event.
          Now connect the battery pack and test the same lines again to see if these lines show any activity. Yes, it is possible that the BMS module on the battery pack has gone into a locked state. Confirm the details of the voltages and check if the battery + lines are suitable for charging of the battery pack.
          • PowerAmpFreak
            • 982
            • Sweden
            Sorry but I misread your first post. The voltages above is with battery connected.
            • mon2
              • Dec 2019
              • 14659
              Locate the charger IC that is onboard. Perhaps will be the popular 'BQ' series by BenchMarq / Texas Instruments. Post the topside markings of this component. While still possible that the battery pack is in a locked state, the battery linked mosfets should also be reviewed for possible damage. If the charger IC is the BQ series then the mosfets will be N-channel type.
              The gate pin of each such mosfet should be higher than the voltage being passed between the source / drain pins to enable.
              In Windows, does the battery get detected? Does the battery charge graphic show in Windows?
              Your scope may offer a SMBUS logic analyzer (LA) feature which can be used to monitor the SMBUS traffic which can reveal if the BMS is locked or not.
              • PowerAmpFreak
                • 982
                • Sweden
                Attached the schematic for the charger IC.
                It's typical sync buck topology.
                In Windows, the battery symbol says battery fully charged.
                • mon2
                  • Dec 2019
                  • 14659
                  Be sure this battery connector is being plugged in the correct direction onto the logic board. Another thread on this forum had a similar fault and was due to the wrong keying of the connector. Suggest to test with a known good battery (Amazon?). If the battery is removed, what does Windows report?
                  • PowerAmpFreak
                    • 982
                    • Sweden
                    The connector is ok, the battery has been working well before. And it's not possible to reverse the connection (poka yoka key). When battery is removed Windows says the same as with the battery, fully charged 100%.
                    I guess it's the battery which is in charge of telling charger IC to start charge?
                    I will try another battery soon.
                    • PowerAmpFreak
                      • 982
                      • Sweden
                      New battery tested and everything works as expected.
                      So the shorted system rail somehow caused damage to the battery smbus / bms controller.
                      • mkdj
                        ASUS X571 no power : battery issue?
                        by mkdj
                        Mark and model: ASUS X571
                        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                        Tests already made:
                        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                        - I have removed...
                        07-14-2025, 09:16 AM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • dhenion
                        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                        by dhenion
                        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                        The original board was:
                        ASUS X510UNR REV 3.0 A
                        The replacement board is:
                        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                        01-30-2024, 01:45 PM
                      • Iherduleikgemz
                        Asus FX505DY - Battery not charging - BQ24780S
                        by Iherduleikgemz
                        Hello everyone
                        I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                        I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                        01-13-2025, 03:54 PM
                      • cope
                        Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                        by cope
                        I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                        Some history:
                        Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                        As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                        Now, with a new battery the system will start up and run off...
                        05-13-2024, 09:40 AM
