MacBook Air A2337 - 820-02016
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    Hello! The MacBook works from the network but the battery does not work! It does not charge the battery! Replacing the battery did not change the situation. Please tell me what could be wrong
  • mon2
    • Dec 2019
    • 13834
    Measure the voltage to ground of each pin on the battery connector on the logic board without the battery. Post each measurement.
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      PPVBAT_AON_CONN=0,884
      I2C_SMC_PWR_3V3_SCL=0,459
      I2C_SMC_PWR_3V3_SDA=0,458
      SYS_DETECT_L=0,489
      • PITERPENY
        • Jul 2023
        • 455
        • Ukraine
        the indicators are identical to the working board
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          If the MacBook works from the mains, then we can exclude the CD3217?
          • mon2
            • Dec 2019
            • 13834
            These are diode mode measurements but a good start. Not shorted.
            Repeat the same test but in dc volts mode of the meter. Be sure that your battery pack(s) are compatible with this logic board. Post each measurement.
            • PITERPENY
              • Jul 2023
              • 455
              • Ukraine
              battery of the same model! and checked by another good payment of the same model! I suspect ISL
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • brockauly
                Macbook M1 A2337 EMC 3598 weird battery charging problem
                by brockauly
                Hi guys,
                If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                Then if I unplug the charger and plug it back, it won't charge anymore.
                In the first case, main voltage is regulated at ~12.5V and charges the battery.
                After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                02-05-2025, 10:51 AM
              • reformatt
                A2337 not working with flat battery
                by reformatt
                Looking for some advice on a 820-02016 board as I don't have much experience with these M1 machines. Learning the nuances of them as I go.
                So the history of this machine was it had been in a bag where a bottle of water leaked. Presented as dead about a month ago, corrosion was mainly around the battery connector and it's sub-PCB. Some corrosion was noted on the board around UC300, CC325, CW1C7, CW1C8. That was it really.
                Now without battery connected, USB-C will stay at 5V and cycle between 0 and 120ma. PPBUS_AON is cycling between 0 to 12.3V. If battery is connected,...
                10-12-2023, 04:36 PM
              • gboone
                820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                by gboone
                Hi, I was given this laptop by my uncle who said:
                • It would occasionally shutdown if not plugged in
                • battery had been replaced
                • touchbar would "strobe"
                I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                BUT
                When powered off, it would at some point have a...
                01-27-2025, 09:12 AM
              • mferna14
                MacBook Air A2681 battery problem after Screen Replacement
                by mferna14
                Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                12-06-2024, 08:10 PM
